Did you install the kernel as well? Also someone else in the thread said turning off CRT animation helps with the Black Screen of Death.
No.. It says that cus the kernel has loki support...meaning that u would be able to flash without briking...I watched the log as it installed. It said "Installing LOKI'd kernel." Unless there is a modified kernel I am missing?
Nope
From any those are the host links... It longest are full.modular.packages...
Flash rom...
Flash kernel supports...
Flash gaaps...
Reboot
No its all in one shot then reboothow do I instal Gapps? Do I reboot and go to recovery mode? I've been trying that but I just reboots
DL android tuner or similar app, open Build.prop editor, find (persist,audio handset, mic) ;change the setting from"digital "to" analog " this has removed the echo from the receiving end of my calls. You can also go to page 10 of this forum and read post from Mn1968 that refer to these issues.Are you going to be updating the ROM to resolve the echo issues? Call quality is a major issue and GPS half works for me. Thanks for not giving up on the device.
If u hav Carbon installed u do not need recovery.apk neither rom manager... U just need to reboot press home botton until recovery comes up... In few post back u would fine gaapsCan someone help me or point to the steps to install Gapps or revert it to stock.
I have Carbon installed, the recovery.apk and the Rom Manager. When I go to recovery mode, I only have the option to factory reset and cancel. What else do I have to do or what am I doing wrong. Help!![]()
Thanks for this!! Helped a lot.Although many users have reported that this ROM has better in-call volume I too still experience the same issues as you, however, I have been able to tweak the snd_sitar file and build.prop and can now enjoy normal sounding calls.
snd_sitar - Copy and replace to /etc/snd_soc_msm. Set permissions to rw-r-r. I have increased the voice call volume, and tweaked a few other things. Unfortunately, none of my tweaks seem to work on increasing the speaker-phone volume.
For call echo, I have tweaked the build.prop with information found in other threads. It involves changing the dual mic to analog from digital, among other things. I made lots of tweaks, some that may or may not be needed, but I do not have any complaints about call echo. I have been using this Carbon ROM with my edited files for over a week now and have had perfect phone calls. Copy and replace the build.prop to /system. Set permissions to rw-r-r.
After files are replaced, reboot. Let me know if the files have helped you.
Thanks DM for this ROM and all you do. I am using this ROM and with the in call fixed now it is great. Should I download the kernal or is it integrated with newest link? Like I said thanks again. I am also messing around with ZTE WARP. I know this is off topic but can ya tell me a food stable ROM for it?I have a new kernel you guys can test out with carbon if you want. Has a lot of updates. SMP hotplug backported from 3.5 .. Cpu boost driver with input boost.. Aka boosts the CPU freq when screen turns on.. Auto hotplug driver with both cores online.
Other patches for speed as well
Download: http://www.mediafire.com/?bu3i9u350fm927i
