After i installed this some of my apps dont work like for example google search bar , my gmail, hangouts, apps that i downloaded from app store basicly any idea why? Is there any way to fix this? Thanks
Is it just your Google apps? If so you can try to reflash GApps or try a different version.
Google PA-Gaaps go with the full modular pakage so it wont uninstall launcerYea my google apps well basicly everything i download from the play store once it starts loading a mesage saying goople play service has stoped for like any app i download from app store ? What gapps do i use ?
NopeDid dm47021 give up on this ?
Ah ha rafiki voice " the king has returned "Nope
Did you install the kernel as well? Also someone else in the thread said turning off CRT animation helps with the Black Screen of Death.Results:
BUGS:
Every few times I lock the screen, I get the Black Screen of Death
Have not seen Kernel crashes yet, though I'll call someone on Facebook Messanger to see (That's a good trigger, happened a lot with hroark3's Kernel
Buggy bluetooth, randomly unpairs my devices
FORCE CLOSES:
Settings -> About Phone -> About carbon FORCE CLOSE
Settings -> Carbon -> Vibration -> Vibration Intensity FORCE CLOSE
1+Did you install the kernel as well? Also someone else in the thread said turning off CRT animation helps with the Black Screen of Death.
It has yo be a clean installSo i had this carbon rom here and decided to try the experion rom but didt like it so decided to switch back to this carbon rom but the problem is i cant get it to start it just stays in the boot logo for the longest time then i do a master restart to get my fone to recovery and tryed again and same problem any suggestions im i doing something wrong ? How can i get back to this carbon rom?
with zip copied to external sd
1. boot cwm recovery
2. factory reset
3. wipe cashe partition
Advance setting..
4. format system, cache, data,
5. install zip from external sdcard
Install Gaaps
6. go back, advance, power off
7. power on
2. factory reset
Advance setting..
Install Gaaps
7. power on
http://forum.xda-developers.com/showthread.php?t=2397942
Here and use the full.modular ones
Please read... So u can understand how they work
From any those are the host links... It longest are full.modular.packages...Okay thanks .. So how do i install these gapps and wat link would i download theres 3 link optionsDOWNLOAD LINKS (~341MB)
BasketBuild | Android File Host | Dev-Host
Thanks for all the help.. Im kinda new at this stuff thanks again
