I don't see a circle in the right
take a screen shot of your camera app after you first open it
want to see what it looks like
i also want to verify, you are using the Metro PCS D500 right
Volume and Power button combo when turning on.
thats not how you go into recovery, you need an app like f6 unitilies or GT's rebooter
Will do! Thank you!
My phone will be wiped then, I supose.
Is there a way to completely backup it, to restore it exactly as it is right now after I test it out?
And are there risks, like, that my phone never turns on again?
I have a lot of spare time so I could test it out
yes you have to make a backup with what ever version of recovery you are using
there are always risks that you can brick your phone, and I am not responsible for it if you do, that being said, if something did happen I and many others would help you try to get your phone functioning again
and how do I know what version of recovery do I use?
So, it should look like: backup, flash new rom, test, restore stock rom, restore from backup?
And, how do I restore to stock rom, I have to use LGMobile support tool or is there a quicker way?
I'm really dum (for now) for those things.
Old iPhone user.
Also signal is weak use to get 3 4 bars now only 1
at this point in time the easiest revoer to install is the F6 utils
http://androidforums.com/metropcs-o...root/820352-recovery-loki-cwm-v6-0-4-6-a.html
start with that, see how it goes
download google camera from playstore?
Sorry was at work but yeah don't see it bro
Is there something in the build prop maybe that isn't right ?
I supose I have Clockwork Mod up now.
Is there a guide whick I could follow to make a complete backup, and then to flash this ROM? I don't want to spam this thread.
I'll be sure to post here is a problem pops up.
boot into recovery with the app, there should be an option in recovery to make a backup
Used the link you gave me, it won't reboot into recovery.
Furthermore, I installed ROM manager, and there (I supose) I made a backup.
I rebooted and it's doing "Android is upgrading" stuff.
So, after flashing a new rom, I just opet this same app, and use Restore from backup to restore to stock ROM, or I have to flash stock ROM first and then use Restore from backup option?
This may look way simpler than I thought.
