Dhlongfellow
Member
I've used the cm11 for a few days now, and the only thing that I have wrong with it is the rear camera. Everything else is nice and smooth. Thanks to all the developers and please keep up the great work.
ROFL I need to stop checking this thread daily. I got LG Optimus F6 because I wanted to get away from Virgin Mobile and because I did not want to pay $300 for SGS3/4. The F6 was a good value at $100. I knew I'd miss CM, but I thought I'd be able to get over it. Turns out I was wrong. I hate the stupid bloatware that comes with it which slows down the phone and eats the free space. I so wish I could have CM on my phone. Alas, as it is right now, it's a bit too unstable and it's missing a few crucial features I need (GPS and notification LED). So thanks for all the work, and I truly hope you guys can make it work. In the mean time, as I said, I have to stop checking this thread daily, it just keeps aggravating the pain of having to live with stock bloatware ROM.
That option was removed on kit kat, Here is an example of the change
Disable vibratiom through settings this has been said alot of times.Alright. I'm home and updated my last post. Here is what I said for the lazy:
- Bluetooth is unstable. My Bluetooth headphone will disconnect immediately after connecting
- GPS is unstable. The GPS may work once every 5-6 minutes. GPS Fix app does not fix anything.
- Endless vibration when moving app from app drawer to desktop. Turning off vibration worked, but this is a temporary solution.
- Constant multicolored LED while in recovery.
- Phone will freeze and reboot once every few hours. Possibly overflow from several apps in use.
Last, can anyone confirm 4G using t-mobile prepaid? I have tried every APN, only to find an "R" next to my 5 bars. I assume this stands for "Roaming". I would appreciate help from any fellow T-mobile customer.
I hate the stupid bloatware that comes with it which slows down the phone and eats the free space. .
Same here I deleted everything from LG and install the gooe counterparts but still the LG skin and 4.1.2 was horrible for me so I use this with no issue haha my stock rom has 500MB free and I never had trouble with storageever heard about Root App Delete and System App Remover?
My F6 runs smoothly on stock w/over 400MB of free space wth 45 user apps installed. Don't even need SD card tricks.
Of course I'd like to get KitKat. But not at the expense of the original stock features.
I have to be and get LTE
Reboot happens every so often it doesn't really bother much
GPS is buggy
BLUTOOTH is buggy
We are still looking for options, my GPS and Bluetooth work perfectly but not varies in every rom mate :3
I run Apex launcher, so skins are no concern to me whatsoever.
- phone that can make phone calls
- LTE data - fast;
- GPS;
- IR remote;
- Music player;
- photo camera/photo viewer;
- occasional video/movie player;
- 64GB microSD support;
those are the features I need/want. Everything else is secondary.
As for games, F6 is not a gaming device anyway. And even with CM11/KK it won't became one.
No need to disable vibration on the keyboard man1. I've already disabled vibration, even when using Google keyboard. That is no problem. I'd like to have these features but I can definitely wait.
2. I would like to get LTE with t-mobile prepaid, as I received before, but I'm in no hurry. I don't see "LTE" though. If I can be directed to the correct APN then that would be great.
3. I don't understand how your GPS and Bluetooth work perfectly. Are you using CM11? I feel the redundancy of noting other Roms, as they are based on stock. I can work around getting no GPS, but in the future, getting all the GPS satellites is a must. My vehicle's GPS is outdated with outdated maps, and I live in a constantly changing rural area. I might be lucky to get signal to initiate the map, and I have to figure it out from there. Bluetooth is buggier than expected. I can discover Bluetooth devices, and the devices themselves will say they are connected, but the phone says "connecting...". This leaves an endless loop where it tries to connect but no success.
Well KitKat can control my Xbox, VLC can stream the movies form my phone to the Xbox and YouTube can control the YouTube app on the Xbox lol so I do have a smart TV x3Or get a smart TV
My LTE speed is better than on stock.
My GPS works good
IR I give you that one I do miss it
Music player is better on CM11 cuz of the lock screen music control that stock doesn't have-.-
Honestly screen is not worth watching movies but I do use YouTube occasionally
I have a 32GB SD card and it works flawlessly
I only have clash of clans on my phone as my only game
Honestly I think the only things missing in this ROM for me is LED and IR. Everything else I could careless haha and fix the vibration but I'm still finding a way to fix it.
