not until US releases sourceAny solution for the back camera??
u need to factory reset reinstallI know it's a noob question but how do I get out of the boot loop? I installed the rom then all I can get to is the CM logo.
ms5001i.kdz root it then g o to recovery n reflash
Thanks, unfortunately I don't know how to get from the boot loop to the recovery. Is there a key combo I need to use or some software or what?
Okay so here is a list of everything that's not working or not working as it should.
1. QREMOTE
2. LED
3. DEDICATED CAMERA / QUICKMEMO BUTTON
4. init.d
5. GPS
6. VIBRATION
7. CAMERA (3MP)
There's more but I think we can all agree these are the most important.
If you install Google camera from the play store you get full amazing HD 5MP just saying1. Port the code from 4.4.2 build from euro KK... should work in 4.4.4
2. Torch?
3. There is code you will have to add (port from 4.4.2 and your almost done)
4. What are you talking about? Works for me....
5. GPS fix and then it worked fine for me.
6. App: VIBE (kinda.....)
7. Team BBQ
2. Torch?
7. Team BBQ
I don't think there's been an update for cm11 yet. I still get random reboots quite often.Has the random reboots been fixed yet. This is the only thing making me want to restore my back up or go to another rom. What makes it bad is if you are texting and need to get your point across you have to wait for it to reboot which takes some time. And I mean that is the only thing bothering me. Everything else is A++
Oh also the in call volume. I can't hear or they can't either.
Hmm, I tried to do this, but it isn't working properly for me. When I flash the gapps it gives an error, then when I reboot, it gets stuck at the cyanogenmod screen and does nothing but loop the animation. I've tried wiping and redoing it over and over, but it does the same thing every time... Any suggestions?
