johnsan1234
Member
Also my phone still says t-mobile even though I have metro. Does anyone know what to do? I set the APN to metro. But my lockscreen still says metro. I appreciate the help.
Hmm. Strange. Well that's ok I can deal. Its not that bad.I use power amp with no probs
If some notices let me know. Does the reboot happen mostly when manually locking phone with power button? Seems like that's what it is for me, but didn't think about it till just now. Just curious..
also the ear piece is low too dont know if you have noticed, i noticed that while in a call the volume was waay too lowMic volume is low. I was doing a facebook call with my cousin and he said he could barely hear me. Tested with sound recorder by blowing on the mic and its still low.
Mine does too, I think it's just that we use T-Mobile towers. It still works fine.
Mine also says t mobile after changing and restarting several times. I think you are right about us using t mobile towers plus if I remembered correctly T-Mobile and MetroPCS were suppose to merge. Idk I could be wrong but it don't bother me to much. Great work all devs breathing life in this phone. I haven't been on cm since HTC and cm7 days lol so thank you guys for this experience.
Aren't omni and aokp pretty much the same ?
I don't know of anyHas anyone tried using a 3rd party remote app with this room?
I installed the ROM today and had a few issues from the get go. I'm not new to the custom ROM flashing scene and it's not my first rodeo. I'm usually able to get past the few hiccups that come along.
Did my backup. (Xperion ROM)
Wiped/Factory Reset, Wiped Cache.
Installed the ROM from zip
Installed gapps linked to from OP. This is where I had the first problem. The gapps install aborted. I booted in to the ROM, skipped through the setup installed F6 utilities, rebooted into recovery again. Tried gapps again. Aborted again. I moved on.
Installed TitaniumBackup through recovery.
Booted into the ROM, went through setup. Disabled vibration, changed my APN, changed my preferred network to MetroPCS. Rebooted. No indication of LTE, phone still said T-Mobile. I was able to receive a phone call but with no ringtone.
I proceeded to restore my apps and data through TiBu. About 50% of the way I ran out of storage. Went into Link2SD and started linking apps. Noticed that I did not have Link2SD Plus. Went into TiBu, restored Link2SD Plus. Still no plus version. Ok, decided to try and download it from the Play Store. Could not connect to the store. Not sure is this was related to the gapps failure or not having my network setup properly.
Through this entire process I had random apps throwing " app such and such has stopped" messages.
Has anyone else had issues with gapps aborting. Is anyone using a different gapps that the one linked to in the OP?
Once I get that issued solved it's on to the network. Any suggestions. Any particular steps I have to do?
My next run through should probably be an incremental restore a little bit at a time with TiBu starting with Link2SD Plus.
So far the ROM looks good. Boots quickly, runs smooth and looks nice. Looking forward to getting deeper into it.
yeah i noticed that too it happens really often thoeSomething I noticed while using cm 11 is that when I listen to music on power amp music player my music kinda scratches and messes up while it playes. I don't know what to make of that. But its just something I noticed while using cm11.
