My maps is what's accurate.U sure its GPS and not location services
ok so i have had this rom for a little over 12 hours.. props to the dev awasome rom ... but there are a few things that i would like to address and i hoping that my request to get looked into.
1) there is a problem with the 4g n 3g signal. now on the stock rom i have never seen the 3g icon before and at home im either 3 baring on 4g lte or full bars on 4g. i have notice that i stay stuck on 3g 100 percent of the time im home before i use to get 8-11mbps down but now im only getting 2mbps downon 3g. but when lte kicks in the signal is low to non but the speed is there atleast. i also have never the Hspa 4g+ either.
2)this is really bugging me here but i everyone i talk to says, they hear themselfs echo. and this was after i took the beta 4 update please look into that !!!
3)i would also like to request to inplant a sd hack to add for more internal storage. i know there is a guide out there but im hoping that you being a guru that you are that you can find a intergrated way of doing and letting the user pick how much space they want to use.
4) maybe tweaking the kernal to under volt it for prolong battery life. i havent really seen a difference in battery life.
5) hmm another would request would be if possable to have a defalut work arounf the upsell so users can have hotspot or tether. i have read threads from other phone on lg having the ablity.
6) a knock knock coding would be cool
I just tried with nova launcher and in less than 5 minutes my phone rebooted 3 times. So I don't think that's the issue with this. At least I don't think that's it. :/Just curious if anyone has tried a different launcher, theme, or ui and see if reboots are still happening? From what I read on some other lg phones with CM11 that it is systemui that makes theirs reboot.
GPS working great on MS500 hardware rev 1. Did you do a complete wipe? I.e. wipe data/cache and dalvik cache?Just to inform you hroark, the GPS still does not work. It does not pick up any satellites at all.
This includes the release you put out to fix it.
1) You know t mobile's 4G is just a re-brand of 3G? So technically, you are getting 4g... just not LTE. (In actual terms, 3g and 4G LTE is different) stupid T-Mobile xD
2)The one of "may be working but also may have bugs" he stated was call and text... He is really working hard on it to improve it!
3)SD card, I believe he can do it and work on it as his main priority.... or do you want him to fix your echo calling or something much more important before that? Some peeps can't even get their camera working
4)Undervolting, overvolting... I believe you could do that but if you really want to juice out the battery, get an extended battery
5)Yes there is a way to do that. You can get an android tether and one of "developer" task managing app. Run the android tether and delete hostpad.(something) or force close it and it will let you bypass the "up-selling" thing you are talking about
6)I know! I want that! My sister is going to get L90 soon and that's pretty much only thing I'm jealous of!
