With my history of USB tethering across multiple phones, it's usually due to a lack of proper drivers on the OS. XP was really good at this, not sure how 7/8 fair, though.Ok, another update. Failed to get the USB tether to work so far. My next idea is to try and download the drivers for the version Hroark is building from and see if maybe that will trigger the tethering option on the device. I'm pretty much assuming everything on the inside is the 505 with a few module changes in the kernel for different hardware and text files that identify with this new hardware. Anybody experienced with this that can tell me if I'm right or wrong about this?
Has anyone tried the sound fix yet? I'm sure it works, because it worked for me, however, I would like some info from others about it.
So, it works for everything except video recording on the camcorder.. I'll add that in later.![]()
Flash this, and then try your sound... I upped everything just a dab.. but I really upped the mic on the other end because it was real low.. I called my other f6 (stock) and it was loud... loud enough.. (almost too much)
Link
The audio fix didn't work for me and I had trouble hearing as well as the other person hearing me in a call. For now, I've had to switch back to the standard rom because this rom just isn't quite ready yet for a daily driver.
The Gapps in this thread don't work correctly for some reason, that is why it crashed.. Use this Gapps: Link
Hello and thank you to everyone involved in this project.
My Metropcs F6 arrived today and I just installed CM11
while installing Gapps the installation was aborted but it seemed like everything still installed? anyways I havnt had any FC yet and the only bug i seem to be having is no back camera theres not even a option in the camera app to swap cams.
