ah wipe does not matter me thinks
what I would like is a logcat from boot, and open camera
do you know how to do that ?
I FOUND THE SOLUTION TO THE IN-CALL VOLUME FIX . It wasn't my idea, but I found it online!
Have you experienced an increase?
I'm not sure if my speaker phone volume increased, or it's just placebo.
I increased all the digitalvolume values I found. They were all 68, and I changed them all to 75.
How loud have you tested?
You only change the RX5 value, the rest you keep it at 68%
so it would be
"RX5 Digital Volume' : 1:70"
I changed mine to 70 and it's the same as stock phone volume, speaker noticibly is louder. Make sure you don't forget to Mount R/W and then save the text file and reboot, tell me if you have any further issues. And if you wish to make it louder, go by 2s, because the differences between them is quite large and i'm sure you wouldn't want to mess up your speaker either, it increases the volume for speaker of the in-call and regular without speaker.
I changed them all to 85.
Doesn't seem that loud or it will blow my speakers, but we'll see.
Yes please send the file so I can look it over. Thanks.
In this case you don't need to flash.
Just using a file explorer with root is fine. Copy the file, and paste in the location overwriting the file and reboot.
Off hand I DoNt know the exact steps to make a flsshable zip.
Hroark
In case you missed it there's no way to turn off the device except pulling battery. And when trying to charge with it off once plugged in phone starys automaticly.
Also thanks for all the work. When I can afford to I'll donate some
Here you go
https://drive.google.com/file/d/0B-XFKxkXVPh4MW5JYUF1cDZwZjg/edit?usp=sharing
replace snd_soc_msm_Sitar with this file. Make a back up first and then tell me if you found a difference in speaker volume when in-call. Don't forget to reboot after replacing the file.
I don't know if the camera problem has been fixed or not but I think if he makes each module for the different cameras to work, can't he just include all the drivers in one package and let the firmware detect what kind of camera it is and load the correct one? Just saying, I have not been on this thread for a while.... Sorry if i didn't catch up but I just couldn't get through 20 pages of posts.
I was way off base I think it says kernal crash I will pull the dump in a minI installed this ROM on LGMS500 FCC ID ZNFD500 H/W 1.0 Date 02/2014. My Problem is the dialer crashes the phone when i press red hang up and the speaker phone doesn't work at all'. I really want to use this ROM. I was thinking maybe there is a way to port the dialer from the euro port to this one because the dialer from that one works perfectly. I would use the euro port except i have to jump through hoops with the launcher
