It vibrates really good![]()
Once GPS and data are fixed its a keeper. My brother relies on me to tether my internet to his electronics![]()
Let's not forget about IR blaster and QRemote, hopefully from G3![]()
Oh sorry.. Just wanted to help
You might so want to wait for them to fix the other heating
It says: "male" in your profile
In any case, don't get too excited about this.![]()
Haha this isn't a dating website for you to check my gender.Just an idea, couldn't you use the D505 Kitkat's modules and libraries and incorporate them? They are both KitKat after all and it seems that everything is the same between the D505 and the D500/MS500 except the camera sensor and radios. I feel like the GPS and Bluetooth modules will be basically identical enough to be interchanged. Anyone with me on this? Can anyone conform this?
Great work by the way, keep it going!
some notes:
The kernel source code and all of the proprietary binaries except Adreno are from the Euro D505 Optimus F6 wich has Kit Kat, I was able to download the kdz file for that phone and convert it to usable files
what make you think that I am not
I am using as much of the 505 KK files as I can, but have had to switch to some of the JB files to some some stuff working
I am getting random reboots and when i boot again it gives me a sim error, a reboot will fix but after some time it will happen again anybody getting this?
Yeah I'm getting the same issue with the vibration on your last build . can still only working with FFC.
I appreciate you reporting issues
when reporting problems, it would be helpful for me to know on which build it was
is this a new problem with the new vibrator build or some other build
have you modified it at all, are you installing apps
the devil is in the details
