Is the ir blaster working?
Downloading this now! Never been so excited to seek out bugs!
Keep up the awesome work guys!
EDIT:Would modifying the build.prop to change the metro values to tmo_us make the tmobile sim work?
EDIT2: Nevermind I can text fine if I change the APN settings to TMobile LTE
Using root dim to turn off the flashing LED till its fixed. Everything's fine so far
I used rootdim and went on the other lights settings and put them on a value that shuts them off. Don't remember what I did as I'm back on JB for the meantime.How you get the led to stop
Just thanking Hroak13 , cod ninja , pressy for what they have done for the development for this phone just a month ago it was dead and in literally over 2 weeks it has changed and we have a pre alpha for cm now which opens the doors to a lot of other projects. So thanks for being genius's amongst us .
Anyone else I'm forgetting u r appreciated
wwhen data works this will change to beta?new build with wifi
https://www.mediafire.com/?324gi029bupiinz
md5sum 1bdca0ef389a6675626f15a6f8dee5d8
All we need is data now !!!/
Lemme me rephrase I need data don't care for NFC or GPS
Car has built in nav
