Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Cm14 will not introduce any revolutionary changes, read my other post ;) This is why I'm not willing to buy a new phone just because of that :D
L70 does not support OTG, as it's hardware simply doesn't have this feature. I wonder how you were able to use it with cm12, then? :)
I know the changes of The cm14 is not a big thing i buy a new phone becouse i need more performance forma playing emulators and other games who needs more performance (idolm@ster is one of them)
lg l70 did not know that did not support OTG then not know how it worked in CM12 just connect it and ready :)
@vm03 are you planning to fix offline charging for CM13 anytime soon ?
I've tried to charge offline yesterday and still we have no charging screen (charging icon appears only for a sec)
hi friends
i installed this rom and i have a big problem with it,when i wana conect to my wireless show this error"authentication problem"
please help me to solve this problem,thanks alot.
hi friends
Probably a case of wrong password. Check it again.
No i try many times with other devices and conect but this time didnt conect its not realeted to password.
No idea what can be the cause, but you may surely try to reboot your router first.
Never had such problem with CM13 and I use WiFi everyday.
Also, you may try "forgetting" your wifi network and create it from scratch within CM13.
Excuse me, i got some problems.
As expected after i sent my phone to repair service, all my data is gone. I tried to instal cm13 again using method that worked before.
So here is those problems while i try to unlock the bootloader.
1st, when using fastboot i got stuck in a screen with LG logo and some line of words.
2nd, when using terminal emulator it seems like the app cant find/access aboot.bin.
I believe i was using terminal emulator method before.
Any suggestions?
@Reinamara , after reading your post and looking at your pictures, i strongly suggest you stop messing with your phone. Be happy it works now. I say this with all the best intentions. With root and dd you can do a lot of damage...
Hi. I recently flashed stock because I got a bootloop problem which lead to the dbi err fatal purple screen. Anyway I managed to fix it, and revived my d325, the problem now though is when I try to flash Cm13 again it is still stuck on the lg logo (bootloop). It will stay on the logo for a few seconds, maybe 3 then it would vibrate screen flashes and lg logo again then it boots straight to recovery. I tried 3 different versions of cm13. None of those zips are corrupted. I got an unlocked bootloader, patched aboot and twrp 3. Basically I'm set up for Rom flashing. I thought reverting to stock rom will fix the problem, but the boot loop is still happening. Anyone can suggest a fix or have experienced the same?
I'm back on stock rom and I cannot handle it. -_-
Off topic:
Did anybody get an update on official firmware? Few days ago, I checked for firmware with the IMEI checker link (the one that gives you the link for the latest oficial fimware for your device and carrier, and saw I can download v10d firmware for my d320n (which, as you know, I don't own anymore). It probably just have stagefright and quadrooter exploits patched, but hey, It's nice that LG is still providing support for this device :)
Off topic:
I'm on stock rom right now. Says Im on the latest version. D325
