PlayfulGod
Extreme Android User
the update will wipe everything n install all anew.
I have cm7 on my phone now, will this update be any better than cm7? whats the difference between the too? I would like to have my mms working right again.
Went right to the URL and it shows a download page, but it won't allow us to download "this file type", so I have gone to it on my PC and to any metropcs site, I get an internal error...if someone downloads it, would you put up a link for me to download from, please?
so should i upgrade me and wifeys phones or not
im rooted shes not..im backing up everything now because
i dont plan on getting a good answer til i get out of school 2night
has anyone downloaded it yet..? I want to know if theres a major difference..
heres the link to instructions.. i notice people asking for the link Huawei Ascend Android 2.2 Upgrade
yes alot of peoples have tried it out, some peoples like it some dont, but i cant blame theme from all bloatware thats on there but there is a way to remove it with root explorer 2.16.
what is bloatware?
useless metro apps, that take up memory and cause the phone to lag...
Where can u you download that explorer thing?Oh okay.. yeah that stuff sucks.. But as long as I can take it off it doesnt matter to me. I just want some of the little glitches will b gone with this updateWhere can u you download that explorer thing?
big downgrade from cm7 to 2.2, but everyone has their own prefs...but 2.2 is clock at 600mhz unless you have cm6 which is 2.2 but clock at 710, same as cm7 is clock at 710mhz also.
So is there any way to get this upgrade, root it, and then flash the CM6 kernel? Because I am LOVING 710mhz. Also, can someone give me some opinions on whether this is better than CM6 or no?
Ok i have had the (Froyo 2.2.2) for 3 days now and it sucks i can not get it to root z4root 1.2.1 and z4root 1.3.0, eazyroot, root explorer. None work on mine. Not sure if metro put some kind of block on it so it cant be rooted if someone finds a root that works let me know (importslife2000@yahoo.com)
Z4 will not work with 2.2.2 You have to use Gingerbreak V1.1 or up, and it works awesome. If you go to the all things root part of this forum you will see a few posts on what you will need to root the 2.2.2 and what you will need to get rid of the Metro bloatware.
is that the only difference? can't you get other programs that overclock the cpu? Let me ask this, in CWM can i do a complete backup of how my system is now, and if i don't like it, come back to it as I never left it?
I want to update to 2.2, but before i do i want to make sure it wont mess up the phone...
will the phone still update if i took off the Canvas-Launcher? I accidentaly took it off a while back, while trying to freeze it...So right now im running solely on LauncherPro
Just want to make sure if updating w/o having the stock launcher, mess with the update? or does the update come with its own launcher?
