Im trying to update to 2.2 i just want to know if updating while not having the original launcher-canvas will affect the update?
And also what's a good app to save or extract all my messages?
to be on the safe side, revert back to stock, and about the messages just send them to your gmail is the best route to go.
Is it ok to revert back to stock w/o having the original launcher?
-by reverting back to stock do you mean reset?
and how do i send them to my gmail? like one by one or how?
-sorry im not too good with the phone haha
reverting back to stock will put your phone to like it was out of box, and yes send them 1 by 1 to gmail...
reverting back to stock, ok power down the phone and download and extract this to your desktop MetroStockRecovery-SCRIPTS.zip after you done that press and hold vol down, end key and tap power, your phone should be on the white huawei screen and it should stay there plug your phone to the computer via usb cable, now open the folder that you extracted and run both of these file, first run fastboot-windows you will see a black box come and leave quick, next run metroPCSStock-windows.bat than another black box will pop up and it will do its thing, once it finishes the phone will automatic reboot itself.
Ok thanks i'll start in a bit if i run into any problems ill be back haha...
Is there any other way to save the messages, i have thousands of messages i want to save... :/
I completed the upgrade took less than 10 mins. I then was able to use gingerbreak to root device. (Root level access is working). Installed Titanium Backup Pro & PRO KEY. Performed backup & Uninstalled bloatware. All is working good so far!
Ash
congrats!!! now if you want to remove the rest of the bloatware use root explorer 2.16 and go to/cust/metro and start deleting the rest.![]()
Which bloatware items are safe for to uninstall? I used list from 2.1. Also whats a free alternative to "root explorer 2.16"? Thanks
Ash
anyone???????Did anyone download from the site before it went "TU"? I went nuts finding the metro app store, but when you go to install it your informed that you need wifi running to install... Win7 is a pain, I set up a adhock, my phone won't recognize it... I'm begging someone to post a link... Puhhhhleeeeeeze?
lol nah, I have it uploading now. I will post a link when its finished.Damn... Am I going to have to beg?
late to the game again bro lol
