No, .... I'm trying to remember where it was, but it's in there...perhaps under "advanced"?...You are on AmonRa recovery?
Edit: try under "other"
but this is fun...no worries
+well i figured i was doing the recovery wrong , which i finally was able to do it right, but still cannot find where to change sig verification, lol im losing my mindO.k. I am back....can you not flash a rom?
I'm gonna fire up my old Evo, and install Amon Ra recovery and see where it is.
This rom you are trying to flash....do you have a link for it or did you find it in the list that is stickied?
I have smelkus mod recovery (based off of Amon Ra) and running Decks Reloaded....Sure, here it is http://forum.xda-developers.com/showthread.php?t=1561680 It was one of the recommended ones at the begging of this thread
What do u have now
hahahaha thats the only one i did not check because of what it was it titled, i didnt want to mess with it, thanks a lot, really appreciate it, love learning new things, do u recommend and JB roms.?FOUND IT.!!
Go to "flash zip from sd card"
You'll see "Toggle signature verification"
FYI, for my evoG, to get into bootloader menu, I have to hold volume UP and press power. Was pressing volume DOWN as directed in the first post of this thread, and had a heck of a time wondering what I was doing wrong... Maybe that will help someone else.
Thanks again ocnbrze and mikestony for your help in the other thread and also for this guide!
Say what? lemme try that again
Edit: yup...I shut my phone off, then hold volume up and power....then bootloader screen. (the fastboot screen to be exact...where the word "fastboot" is in red)
Then power off again, volume down/power....then into bootloader. But this time with the blue text "Hboot" .
wierd huh?
Edit yet again: what hboot are you on? Maybe that has something to do with it.
I could'a sworn it didnt' work before but I get exactly the same thing as you. Vol down/power works fine...will edit my post.Mikestony give the following:
In the op of the rom, post 2(?) you will see 2 different downloads for DTa2sd.
Pick one, I use the beta version myself.
Download it and transfer to your sd card.
Flash from recovery.
Wipe cache and dalvik then flash.
then reboot.
It should move your apps to the sd ext. upon reboot.
If not, go into Terminal Emulator and enter this commmand.
a2sd reinstall
Presto! apps to sd done!
Double check in TB
