new optimus
Android Expert
ya I pop in some times thank you.
flash a rom:
1.first you need the vr superwipe (this is not a rom. this is a file that wipes your sytem partitions and also wipes all the temp files as well:ZZZVR_SUPERWIPE.zip. download it and put it on your card. (optional)*
2.download the rom (i recommend MikG v3.11 [3/9/2012]) of your choice and transfer it to your card.
3.go into recovery
4.make a nandroid backup
5.select wipe from the main menu and wipe dalvik cache, cache, and data
6.select flash zip from sdcard
7.find the superwipe file and select it.(optional)
8.find your rom and select it.
9.reboot.
I have made it all the way down to step #6
I dont see either one of the files. what i do see is my directories. Am I missing soething here?
never mind i had downloaded the advertisment file
Im all about free, that is why i finally decide to root. Got a new tablet for xmas, and im planning on using the hotspot so that i will have wifi wherever.
Do you have a good suggestion? Your guide was was awsome!
thanx
well most roms have the hotspot hacked but it will not work on 4g. however the wireless tethering app does work with 4g but some versions work better then others.
you can get them in this guide:
http://androidforums.com/evo-4g-all...net-tethering-w-evo-4g-3g-wireless-wired.html
Alright, I'm hung up a bit, just need a little clarification.
Step 3 Flash the SU File OR Flash a ROM
I unzipped the Superwipe zip folder and put the contents on my sd card.
I unzipped the MikG zip folder and began to put the contents on my sd card, but there is a Meta.inf folder in the rom folder that is also in the Superwipe folder. I chose to replace any duplicate folder/files. Was that correct?
I go into recovery, but there is not an option for Nandroid.
The nandroid app from Google market/play store says i am not rooted yet if I try to use it when booted up.
The way I am reading the guide is that I either flash the su file or the custom rom.
Do I need to flash the su file and wipe and flash the rom instead?
you are not rooted until you either flash the su file (this is what gives you root access to the system partitions, without it root apps and flashing roms can't be done) or flash a custom rom which has the su file cooked in.
also do not extract or unzip any files unless told to do so. just download the files and move it to the sd card.
also in recovery there should be a backup and restore option. this is where you will make your nandroid backups.
Gotcha! I must have inferred that from a search in this thread looking up some trouble I was having in the past.
For the nandroid backup, I keep the first three (boot, system, and data) checked and checked winmax then performed the backup. What does backing up the recovery do for me, or the other options for that matter?
That info I read but I was curious about the other options in nandroid and what they do. However, I am running the rom right now and going through setup for email so my questions should be posted elsewhere; I'll do some searching as well.
Thanks to everyone for the help!
Hey, I'm new at this and have made good progress - until I tried to unlock the Bootloader. It produced this error after hitting "Submit":
We're sorry, but it appears your attempt to unlock the bootloader on this device has failed. This could be caused by several factors including simple errors in the entry of the unlock token, problems with your device, or a lack of manufacturer support for the unlocking process. Please see the specific error code listed below, and try again if necessary.
Error Code: Invalid Bootloader Token Length.
Error Reason: The submitted Token appears to be the wrong length and won't work.
Any clues?
welcome to the forums!!!!!!!!This is a great forum! The best I could find after hours of treasure hunting!
OK, I'm somewhat out of practice so consider me new at this. Have made good progress. I have an HTC EVO 4G and rooted it 2 years ago. It finally crashed and the tech @ the Sprint Store installed the latest ota which locked it up.
I'm attempting to "re-root" it using the "HTCdev method". I tried to unlock the bootloader and got to the point where I pasted the token info and hit "Submit". I get this error:
Any clues?
Hey thanks for the super quick replies.
I'm using the "HTCdev method". The code I pasted into the HTC app had the word "bootloader" at the beginning of each line. I see now (as is probably true 90% of the time) that I did not read the instructions carefully. DOH!
I'll see if it unlocks now...
Thanks a ton!
You're gonna have so much fun after root it's crazy funHey thanks for the super quick replies.
Thanks a ton!
so looks like you took the latest ota for our beloved evo and now you want to root it. to begin with never accept an ota when you are thinking about rooting your phone. this will apply for all phones going forward. with each new ota, rooting will become harder and harder to do. [...]
WOW! This really work well. SUCCESS!!! I am amazed at how the author(s) were able to take a detailed proceedure and make it so simple! Still blown away at the results. THANKYOUVERYMUCH!!!
welcome to forums!!!!!!!!!I have an unroot question.
This is probably the wrong thread, but will the unroot guide at the beginning of this thread work for HTC incredible 2?
I think I have gingerbread, and I think the phone was 2.3.4 from the factory but not 100% sure.
Thanks
