I'm using Chrome.....I'll try my laptop!
yeah that is odd. maybe check to see if you popup blockers are on because you will get a popup menu after you select the other device option.
I'm using Chrome and it didn't work....Internet Explorer did though...wtf..lol
This is going to drive me BONKERS.....When it asks if I want to continue (disclaimer)...it won't let me click the yes button, but it will let me click no...lol!
......just kidding
To start off, thanks for the guide. I've already given an official thanks, but I just have to say it.
Do you have a recommendation as to the time frame I should allow to root my phone for the first time?
If following the HTCDev method, am I correct in assuming that my warranty gets voided b/c radio is not rooted, which can alert my carrier? Is my carrier automatically alerted, or would this just be if I needed their assistance with something?
welcome to the forums!!!!!!!!!!Is it necessary to remove the internal storage card before rooting to keep my backups of data and programs safe?
7. in the command window type:
Code:
adb shell
ok you should get # in the command window if not then something went wrong.
can you post what the bootloader info for your phone before we proceed?
Thanks for the quick reply and great guides.
hboot 2.18.0001
ok what rom are you currently on? and it says unlocked as well, correct?
and just curious, you mentioned you want to go back to froyo?......why? you do not need to unroot to do that. you can just flash a froyo rom. and to be honest you do not have to unroot the phone to take it into sprint.
ok so the reason you do not have root access is because you nandroid restored back to stock. the stock rom does not have su (superuser) cooked in. su is what gives root permission so that you can change your system partition. without su you can't do certain things until you flash the su file.right now I put back the original Sprint nandroid. Yes Unlocked.
My froyo rom worked perfect.
The music players do not save the spot of any song (audio book ) when they are closed on this phone. I spoke to HTC and they confirmed it is a problem but wanted $80.00 to fix it. So I thought I would return a unrooted phone to Sprint so they can not claim the reason the music players ( all of them) wont save the spot b/c I rooted it.
I tried to restore my old rom but that didnt work. Maybe I need to install the froyo rom fresh and not use my backup.
Nonetheless if the froyo rom wont fix the music player- then I have to return to sprint.
so do you want to unroot or try a froyo rom (or even mikg3.11) and see if that fixes things?
ok -- true -- I have to put the su back on.
what happened when you tried to restore your old rom(nandroid)?
as it was restoring I got 1.5 lines of dots-- and said it was done- seemed to be too short of a restore.
I rebooted and the phone hung @ the HTC 4g white screen
mik has the same music player problem. I brought the issue up there months ago and they thought i was crazy.
I just downloaded the old froyo rom. I will try to load it now and let you know what happens.
But if I can not fix the music with the old rom-- I will just put back the nandroid and go to sprint.
Or I suppose I can try the unroot method as long as I have super user on phone etc.
i just put the froyo rom on -- music player works again. i'm good. thanks for the quick help
Nostalgia !wow that is a blast from the past.
Glad to see ya 'round NewOptimus
