Root [Revised] Rooting Gingerbread 2.3.5 Dummies Guide
I did everything, and on the final reboot, it it shows a vertical loading bar on the right and when that finishes it says its "checking..PC36IMG.zip" file and then says
"Main version is older!
Update Fail!
Do you want to reboot device?
<VOL UP> Yes
<VOL DOWN> No"
what do i do now?
welcome to the forums!!!!!!!
what is your baseband(radio) and hboot? what methos and what step are you doing?
what do you mean? im not ure exactly what that means haha
steps 11 and 12 is where you use the commands that will downgrade the misc partition. in the guide there is a screen shot of what the commands should be and what the ouputs should be as well. it needs to be exact or the commands did not work and you will need to start over.
after step 11 i get a $ instead of the #
then the taco root command did not work.
the whole idea is to use taco root command to gain a temporary root access so that you can downgrade the misc partition. this would then allow you to use any PC36IMG rom file to downgrade to an earlier OTA so that you can use either unrevoked or revolutionary to gain s-off.
so you will need to run taco root again.
unrevo says "rebooting" and then the phone does and unrevo says "communications with phone unexpectedly interrupted. try again"
when i ran unrevoked the evo restarted and unrevoked said it lost connection and to try again? its done this a couple times
and with that, i dont have a nandroid choice, i have a hboot usb choice and clear storage choice
so you do not have s-off then? not sure why you are running unrevoked again if you do like mikey has asked.
if you do not have s-off then there are a couple of things this could be:
1. do you have the drivers installed correctly? you need the hboot driver that is found in the unrevoked wki
2.you need to install htc sync and then uninstall it leaving the drivers on the pc
3.make sure that there is no antivirus running on the pc
4.make sure that there is no sync type program running like double twist or pda net that could cause communication errors.
5.make sure that you have the phone set as charge only
6.usb debugging is also turned on.
all of this can be found in the http://androidforums.com/evo-4g-all-things-root/194918-rooting-dummies.html in the secrion 1, the pre rooting section.
I do have s-off, i just checked again, hboot is 2.10.001 and radio is 2.15.00.11.19. i just need to know how to safely put MazWoz ROM 4.2.1 on the evo? thats what i need to do, im just having a hard time doing it
What recovery do you have? I forgot if unrevoked puts a custom recovery on the phone or not?
When i use the Revolitionary S-OFF & Recovery too command prompt thing it says youre devide: supersonic, with HBOOT 2.10.0001 is not supported at this time
