Root [Revised] Rooting Gingerbread 2.3.5 Dummies Guide
so i type into the command prompt
cat /sdcard/flash_image > /data/flash_image
this time it doesnt say "no such file or directory"
now it just says "not found"
ok that is a start.
hmmmm that is odd.
can you do a screen shot of the extracted files that you have downloaded? i just want to see what you have there.
little embarrassed....
how do i do a screen shot?
there should be a print screen option on your keyboard somewhere at the top. press that then go into a photo editing program like paint(which i use) then you can upload the photo to imageshack or photobucket and then you can post here in af. there is an icon that looks like a postcard. post the link there.
well the only thing i can think of is to do the taco root undo command and re-download those files, exract, move to the sd card again and start over. it could be a bad download, possibly.
ok root undone, rebooting phone. Is there another location I should download from or the just use the liks from the guid page again?
