ocnbrze and Mike you guys are great, I sold the evo so I dont check this form as often.
Thanks new optimus
![Big Grin :D :D](/styles/smilies/google/biggrin.png)
![Stick Out Tongue :p :p](/styles/smilies/google/stickouttongue.png)
Thanks new optimus...Ocn usually beats me to it
I haven't touched my DINC for nearly two years so things have changed a lot in the custom ROM world. And it's significantly more confusing since the directions are all for the Evo.
I've got hboot 2.15 and "successfully" flashed the Amon RA recovery through adb, but when I select "recovery" it just goes to the HTC Incredible splash page and hangs. Any idea what I'm doing wrong?
welcome to the forums!!!!!!!I haven't touched my DINC for nearly two years so things have changed a lot in the custom ROM world. And it's significantly more confusing since the directions are all for the Evo.
Hello! Thank you for posting this guide
I'm new to this whole rooting business, so I was wondering if the MikG rom is still your best recommendation (I noticed that the last update was in October of last year).
Cheers,
Con
Then... on to the next step~
Thank you again!
Actually... I'm back already xD
I'm still on step 3 of the -recommended- method for rooting.
I downloaded the "Rom Manager" app to set up a recovery file, but it says it can't find the "Superuser" ...
Did I miss a step somewhere?
I don't remember ever downloading that.
Err.. Well, I was unclear on how to do these step:
"3.go into recovery
4.make a nandroid backup"
So I googled...
Android ROM and rooting dictionary for beginners | TalkAndroid.com
We're sorry, but it appears your attempt to unlock the bootloader on this device has failed. This could be caused by several factors including simple errors in the entry of the unlock token, problems with your device, or a lack of manufacturer support for the unlocking process. Please see the specific error code listed below, and try again if necessary.
Error Code: Invalid Bootloader Token Length.
Error Reason: The submitted Token appears to be the wrong length and won't work.
I received this error when i submitted my ID token I am just doing an htc dev
I verified the code was the same lie for line by checking the first and last 3 numbers in each line none are missing that i was able to id ran fast boot again nochange what am i missing
doesnt say bootloader or info just the token first line and last lineand all the numbers and letters in between
