nope the reboot from stock recovery is fine. do the undo command and start over from step 5.
In yellow towards bottom of screen, it says
E:Can't open /cache/recovery/command.
that's actually normal.....disregard that.
On step 8, it says the same thing as after step 7
adb server is out of date. killing...
*daemon started successfully*
as long as daemon starts successfully you are good to go.
After step 9, at the end of the long message before the reboot, it says
rm failed for /data/data/recovery/log, Permission denied
link failed File exists
Now it is back to the triangle with ! inside.
hmmmmm i never seen that error before.
what size sd card do you have?
well it needs to have enough room so that the stock recovery can write the log. i'm not sure how much room it takes though. it could be really small, but who knows.......its just a thought.
Ok. I will have to delete stuff later. If i do the undo step after rebooting the phone from the triangle screen, will it go back to normal so I can use my phone and do this again at a later time?
yep you go it.
Awesome. Thank you guys so much for your help. I will definitely be back, lol.
ok got it i was powering the phone off instead of staying in usbfast boot. I have sucessfully unlocked it . which one of the two recovery methods should i use? the flasher or the adb command?
I am ultimately going to flash from sprint to cricket, would appreciate any help you can give
welcome to the forums!!!!!!!!!I'm getting "main version is older" at step 15.![]()
