Glad to see you are moving along well!and how do i move them over when it in usb-ms toggle? like i said im a little slowalso my phone at this point reads unlocked and s-on. is that correct?
ok i have completed all the steps. what now? how do i tell if it worked?
i just installed an app that required root. it would not install cause it says i wasnt rooted?
i thought i flashed a new rom, unless i screwed up. should i still be rooted even without doing that?
superuser app? is that something i was suppose to get from the play store?
i dont have that, guess that means i was unsucessful with flashing the rom. does the MikG file need to be a zip when i transfer it to sd card? or will it still work if i unzip then transfer to sd card(which is what i did)?
good to know. i think i got it all figured out. thanks
ok I am officially rooted! and have the mik mik rom! thank you all for your help! any recomendations on what to do now that i am rootedcool beans. keep us posted.
congrats!!!!!!!!!!ok I am officially rooted! and have the mik mik rom! thank you all for your help! any recomendations on what to do now that i am rooted
Hi, I'm having some problems with the tacoroot method. once i get through step 11, there is a $ that appears instead of a # and it won't let me continue. I had a problem with bootlooping, but i cleared the cache in recovery and that seemed to help the bootloop, but i still get the $ symbol. What should i do next?
welcome to the forums!!!!!!!!!!!ok so i am new to rooting i always wanted to and i got time to and did
i got all the way to here i copied the file after renaming it to pc36img
it shows a bar like loading it...it gets to 100 and says
Main version is older!
Update Fail!
do you want to reboot device?
<vol up> yes
<vol down> no
what do i do????
i am using taco root and at the final stepswelcome to the forums!!!!!!!!!!!
what method and step are you at? there three ways to root and all of them use the PC36IMG files and each are different in their use.
exactlyok then something did not go right. it looks like you did not successfully downgrade your misc partition. are you sure your outputs matched with what is shown in the guide? it needs to be exact.
exactly
