new optimus
Android Expert
when you get into wipe menu you will see, combo wipes, go to superwipe, that will clear everything, boot, caches, data, system and all temp files, it will do it all 3 times you only have to hit it once.
ok perfect, now you will see wipe, go into that, and as a bonus you dont need to use the volume up and down keys and power key for selecting.
the home key, far left will move up, the menu key moves down, and the search key, far right selects. the back key, goes back one screen.
ok hit the back button, til you get to the main menu
go to flash zip menu
choose zip from sdcard
find the downloaded zip you placed on there previously.
Yes, I have heard very good things about MikG I am more partial to pure android roms myself, called AOSP = Android Open Source Project.The rom/zip I downloaded earlier (MikG-v3.11), right? I'm guessing to select it?
Edit: Selected and now asking to confirm install of zip file
some major differences and in looks too.
after selecting and confirming it will install.
That could be it. Can you see the sd card when booted into Android? That will help us confirm whether it's a mounting issue.Yes, the flash_image file that's on the SDCARD is the extracted flash_image file:
49,804 flash_image.zip (original file)
76,044 flash_image (extracted file on SDCARD)
Is the # prompt a typical unix prompt? Reason why I ask is if I change directory to /sdcard or /mnt/sdcard, I can't see anything when running "ls". However, I can go to /data and run "ls" and I do see files - just not the /data/flash_image file because it can't seem to find /sdcard/flash_image therefore the cat command seems to fail.
Yes. While on phone using android, ES File Explorer sees /sdcard/ directory just fine. I see all the files including the flash_image file. However, I'm unable to determine who really owns it and what the real rights are. ES File Explorer reports "-rw" and if I go to the properties of the file, it shows (readable, writeable, and not hidden).
Can you also see the sd card on your computer when plugged in?
o.k...so the problem lies with step 12 correct?Yes, if I select drive from the selection menu instead of charging, I can see the files on the SDCARD just fine. That is how I copied the files to /SDCARD/ initially.
And that extracted file, is not in any folder correct? It should be on the root of the sd card. Sorry for too many questions here..![]()
Well that is good too! After you unlock your bootloader, you cannot use tacoroot. If you want to be s-off, then you are correct and use the Capt. Method which is similar to taco. Thats the process I've used with 2 phones.Yes, that is correct. The file is copied to the root of the SDCARD ( /SDCARD/ ). If you want, we can go the route of HTCDev/Captain Throwback method. I'm making some progress on this method now. I've just pasted my key and am awaiting the email back from HTCDev now.
Make sure you check your "Spam" or "Junk" folder for the e-mail, as sometimes it gets diverted there.Yes, that is correct. The file is copied to the root of the SDCARD ( /SDCARD/ ). If you want, we can go the route of HTCDev/Captain Throwback method. I'm making some progress on this method now. I've just pasted my key and am awaiting the email back from HTCDev now.
do you have fastboot unchecked?Ok, I'm a little bit curious of what's going on now. Since completing the first phase of HTCDev, my phone boots amazingly fast, but I can no longer get to the boot menu by clicking on [power] + [down] to install recovery. Once again, the phone boots amazingly fast. Have you seen this? Suggestions?
Thanks.That Capt. guy shore do be a smart feller!
@Capt---you did a fantastic job with that guide about removing watermark!
One quick question, and off topic, what is you avatar a picture of?
Ah, gotcha, makes sense now lolThanks.
I took that pic at Niagara Falls. I think it's saying not to climb over the rail, but I found many signs in Canada confusing.
