vailpass
its all good. are you in fatsboot on the phone that is accessed by the bootloader? in the bootloader it should switch from fastboot to fastboot usb.
Checking to confirm fastboot mode now
*EDIT* Got my token. Copying and moving to next step.
NICE!!!!!!!!!!!!!!!!!
Just got his phone unlocked! It's my son''s 14th birthday, he's been wanting to root and I felt 14 is the age when you are old enough to void your warranty. Going to go figure out how to get recovery and flash MikG for him now.
Couldn't have entered the root world last year or rooted my son's phone today without ocnbrze. A sincere thanks to ocn and to all the community here that is willing to help without judging.
Cheers!
Welcome to AF!!Hello- I'm having trouble getting the PC36IMG.zip to load in bootloader. I have done everything correct up to this point, but I keep getting a no image type of error. I've checked and it's not filed as zip.zip. I downloaded multiple times and checked the md5 and it is also right. Below is the message I'm seeing while it's trying to read the .zip file.
SUPERSONIC EVT3 SHIP S-ON
HBOOT-2.18.0001
MICROP-041f
TOUCH PANEL-ATMEL224_16ab
RADIO-2.15.00.12.19
Dec 21 2011,12:50:32
When i enter the bootloader it says SD checking
loading PC36DIAG.zip
no image
no image or wrong image
loading PC36IMG.zip
no image
loading PC36IMG.zip
Please HELP
Yes it is in root on the sd card and yes I am unlocked using the Htcdev method using Captain_throwbacks methodWelcome to AF!!
Do you have it on the root, or the top level (not in any folders) of the sd card?
Edit: can I assume you are unlocked now by using the htcdev method?
ah, gotcha, so you are on step 10 of his method?Yes it is in root on the sd card and yes I am unlocked using the Htcdev method using Captain_throwbacks method
10) Using the previously downloaded Froyo PC36IMG.zip from the OP, rename to "PC36IMG.zip", and place on root of SD Card. Reboot into Bootloader, and follow the prompts to update device (Notice in the below picture that the watermark shows as "LOCKED" again).
No problem!Yes it is in all caps. haha. I thought of that also. BTW thanks for helping
HBOOT-2.18.0001
MICROP-041f
RADIO-2.15.00.12.19
no image
loading PC36IMG.zip
no image
loading PC36IMG.zip
Please HELP
yes but he did not mention the strip on the top before it says S-onHe mentioned he was unlocked![]()
the watermark still says *** unlocked *** at the top. everything else is the sameif your not seeing this
Then its not unlocked to be able to use the zip
so perhaps it does not.
he could have thought it unlocked but it did not.
eh, don't know about that.yup, i tried a new sd card and it's still doing the same thing. someone said they had to downgrade their radio and then it worked. but I do not know how to do that.
it's doing the exact samething. it's like it's reading the zip file and trying to load it but it's saying there is not image.eh, don't know about that.
The .zip you are trying to get working, is it the .zip that will be used with unrevoked?
If so, try the other .zip to be used with Revolutionary.
Here is that .zip...direct from the Capt guide on mikmik
Dev-Host - PC36IMG_SuperSonic_GB_Sprint_WWE_4.54.651.1_Radio_2.15.00.0808_NV_2.15_release_220182_signed.zip - The Ultimate Free File Hosting / File Sharing Service
Edit: just be sure to delete your current PC36IMG first.
Did you rename that file in windows?it's doing the exact samething. it's like it's reading the zip file and trying to load it but it's saying there is not image.
AH!!!! the one question I forgot about...THANKS OCN!ok basically what you are seeing is what the bootlaoder is programmed to do. it will always search for a specific file name. if it does not find it then it will give you the no image or wrong image found message. so the bootloader is not finding it for whatever reason.
what size card are you using?
I am using an 8 gb sd card.ok basically what you are seeing is what the bootlaoder is programmed to do. it will always search for a specific file name. if it does not find it then it will give you the no image or wrong image found message. so the bootloader is not finding it for whatever reason.
