Well I have this running with v6 super charger script . Nitro lag null. And kick ass kernelizer and this rom is booking lol HUGE difference.
Edit: ran quadrant and got 2100 with CPU set to 1ghz. Smartass2 , so.
is this with Wi-Fi on or off?
Well, my humor sure got misinterpreted. I was trying to express my amazement at the rapid pace of development. Please, I meant no offense!Pretty sure that was sarcasm. If not, we can all just ignore it. The devs know to work at their own pace.
It seems that init.d scripts are not working. Can anyone confirm or deny this?
Im on ALPHA 0.5.1.2 with a Huawei X6 u9000
Market gives me server error, I have tried to he flash the Google apps package several times.
Seems like there is a bug with the "back button" its acting strange or is this a feature.?
I can see some of you are using proxies for Google voice, can you recommend some?
Thanks for a nice build
im still wondering why drivers cant be moved from stock build to a cm build without any hassle?
Somebody might know better than me, but I wonder if your back button issue could be because your using a different device?Im on ALPHA 0.5.1.2 with a Huawei X6 u9000
I'm thinking about building every day, at least for myself. My build yesterday got 40 downloads, so it would appear there are a few people who appreciate it. Here i my build for today:
NOTE: You need to flash gapps every time for ICS ROMs. Even if you're upgrading without wiping, you still need to flash gapps.
Another small issue (probably tied into the battery icon not changing) is that the keycode lock option to not have to click OK (I think it's called the Quick unlock or something) doesn't work and I have to click OK.
BUT.. Proxy on Wifi works like a champ!!!!!
I dont know if its just me but the alarm doesnt work. The clock stops running if I try to set an alarm. Is this a known issue or could be fixed easily?
Also I really liked the feel of ICS on my Triumph and wanna say thanks to everyone involved.
my alarm is working fine I have 5 everyday at 8,9,10,11am n 12pm
F/NetworkStats( 3327): problem reading network stats
F/NetworkStats( 3327): java.lang.IllegalStateException: problem parsing idx 1
F/NetworkStats( 3327): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:300)
F/NetworkStats( 3327): at com.android.server.NetworkManagementService.getNetworkStatsUidDetail(NetworkManagementService.java:1282)
F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService.performPollLocked(NetworkStatsService.java:831)
F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService.performPoll(NetworkStatsService.java:799)
F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService.access$100(NetworkStatsService.java:128)
F/NetworkStats( 3327): at com.android.server.net.NetworkStatsService$3.onReceive(NetworkStatsService.java:633)
F/NetworkStats( 3327): at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:728)
F/NetworkStats( 3327): at android.os.Handler.handleCallback(Handler.java:605)
F/NetworkStats( 3327): at android.os.Handler.dispatchMessage(Handler.java:92)
F/NetworkStats( 3327): at android.os.Looper.loop(Looper.java:137)
F/NetworkStats( 3327): at android.os.HandlerThread.run(HandlerThread.java:60)
F/NetworkStats( 3327): Caused by: java.io.FileNotFoundException: /proc/net/xt_qtaguid/stats: open failed: ENOENT (No such file or directory)
F/NetworkStats( 3327): at libcore.io.IoBridge.open(IoBridge.java:406)
F/NetworkStats( 3327): at java.io.FileInputStream.<init>(FileInputStream.java:78)
F/NetworkStats( 3327): at com.android.internal.net.NetworkStatsFactory.readNetworkStatsDetail(NetworkStatsFactory.java:269)
F/NetworkStats( 3327): ... 10 more
F/NetworkStats( 3327): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
F/NetworkStats( 3327): at libcore.io.Posix.open(Native Method)
F/NetworkStats( 3327): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
F/NetworkStats( 3327): at libcore.io.IoBridge.open(IoBridge.java:390)
F/NetworkStats( 3327): ... 12 more
