FroyoShark
Antutu benchmarks get stuck at 85% on SD card write speed.
Did mantera confirm progmanos fix for mms? Just curious. Running its now. Seems better than previous version. It may be the screen drivers... Not totally sure though.
Wow... I'm able to overclock to 1.9ghz stable on here. The max I could ever get without a reboot on CM7 and MIUI was 1.4.
EDIT: It's even stable at 2.0![]()
Yeah, I don't think the OC is working right at this time. Needs more work.
It seems like it is... The performance section says it's reaching 2ghz.
EDIT: It also seems more smooth overclocked, though it could just be my imagination![]()
Couple of questions, are we going to have to flash gaaps everytime we update for a while? And also, am I just missing something or is automatic connections to wireless still in the works?
Thanks for all the work!
What is the proper method for updating CWM? I'm planning on loading the alpha but need to update to the latest clockwork mod?
I'm having this problem as well-- after I enable wifi, I then have to manually tell it to connect to my network. I could have sworn that it was auto-connecting on 0.5.0, but maybe I'm imagining things.
anybody experiences poor signal? at the same spot CM7 gives me -68dbm, but CM9 only has -91dbm......
btw i am at lower Manhattan.
setup wizard has unexpectedly quit, I can't get passed this screen, any reason why I'm running into this road block?
i have the latest clockwork mod
wipe data/factory reset
flashed gmapps
and rebooted x2
