Ok, thanks, do you know how can transfer apps from one google account to another?? I contacted some of the devs and they said its not possible to do it on their end??
I use Dolphin Browser. It closes like that when you back out (or long press back key to close) I can't help you with the stock browser as I haven't used it on CM9 yet.When I'm on CM 9 and I'm on the internet, example, I will go to CNN,then I will back all the way out,then Ill restart Google again,it takes me to the CNN page.How do I perm close a web page when I'm done.When I was on stock,it gave me the option of closingall tabs.This cm9 doesn't give me that option. I've noticed my battery drains more when web pages are not perm closed.
The OnLive stuttering is likely due to your own internet connection, it runs perfectly on my phone.
one thing I just found out is NOT to use a battery saver. They just keep the phone from going into deep sleep. I can leave all radios on and the phone will deep sleep and sip power.
I had a question - when upgrading from a previous CM9 build, can I just wipe the caches like in the CM7 ROM, or is it recommended that I do a factory reset?
Alpha 0.6.8.9
-updated kernel version to 2.6.32.11 (note: I had to leave the kernel version showing as 2.6.32.9 because changing the version number broke wifi)
-Added net data usage limit (thanks to NakeMcKn for reminding me to do that)
-Updated build.prop to ICS ID so Chrome works now
-Removed OpenWnn IME since nobody uses the Japanese IME
-Possible fix for headset media controls added
Let me know if the headset media controls still doesn't work since I don't have any way of testing that. Thanks.
I also added this to the Not working section:
-Known issue: after flashing, you may need to manually connect to your wifi the first time. After that, wifi will only autoconnect every other time that you toggle wifi on and off. You can manually reconnect at any time though. Needs to be looked into further.
Quick question Mantera... I noticed the file size is a little bit smaller now. Is that due to you taking out the OpenWnn IME?
Sweet, now I can get rid of the annoying warning that appeared when I passed 2GBI also just wanted to add that for the Data Usage limit, see the attached screenshot:
You can manually move the orange warning line (and the limit line if you enable the Mobile Data Limit) by touching the line and sliding it up or down. The default is 2.0 GB for the warning so as you can see from my screenshot, I upped it to 2.5 GB on my phone since that's our limit.
And to think, I was just saying earlier today "It's been a while since the last alpha update" and look here we are
After having wiped my microSD, It seems that CM9 is having issues reformatting my card. I guess I'm stuck with 0.6.7 till I can get a card reader
i definitly agree with youDoes anyone notice a huge difference in touchscreen responsiveness with this ROM? Maybe it's just me but it feels improved by 10 fold.
Did you remove voice actions in the new build? I notice that it's gone. How can I get it back? I like to setup my alarm using it.
