Raptor5150
the settlers hd doesnt work ether
I have just flashed cm9 and installed Google chrome. When I try to run chrome, it says unable to run because I need pics 4.0 or higher yet when I check my version, it says 4.0.3. Any ideas?
It's an issue with chrome.
Regarding the Chrome issue, I've got some updates to the build.prop in the next release whenever that is. Looks like the fingerprint was still showing a GB build so I updated it to the ICS build ID and that should take care of the issue.
Are you planning an update soon? or could you post what the change to build.prop needed.
I'm pretty sure the build.prop change required is "ro.build.id=IML74K"
can someone tell me how to delete a post i put up
Out of curiosity, have the wifi/bluetooth battery issues been solved yet? I'm running MIUI and every time I turn on wifi it seems my battery is dead a few hours later.
I am also experiencing the same problem as projectmayhem, lost 3g signal and airplane mode toggle or restart of the phone would fix it..
wifi/bluetooth is indeed fixed but it's alittle choppy when say playing onlive but it works wifi deep sleeps now so not much battery impact now..
having the same issue kinda sucks........but great work on the rom guys!!!!!!! having one other issue when i type a keybaord symbol comes up in the notifacation bar.......any way to stop that?????
So to avoid reading through a whole thread, what are people's opinions on this rom? Is it worth it to drop MIUI and make this my everyday rom (I know camera isn't working and I can deal with that), or should I wait another month or two?
