hydrowolfy
I downloaded the latest release 3 times. Same result each time. If this doesn't work, I'm going back to stock and going to sleep. Work in 6 hours, wooo.
Hey OG, just to let you know you're not the only one having that problem. Although I didn't test it as extensively as you have, I deleted /system and the cache before attempting to update from .6.5 to .6.10.3 and I got the same error. I've got some ideas on what they might be. I'll let you know if I've found anything.
Edit: don't you love it when the first crack pot idea you come up with works? Okay, so basically I was able to get .6.10.3 to install by first wiping /system and the cache, then installing .6.5, then booting, the rebooting back to recovery and deleting cache again, then installing .6.10.3
I'm guessing it's not necessary to boot .6.5 and deleting the cache again but I wanted to leave it there in case I'm wrong. Basically, what I think the problem is is .6.10.3 is missing some critical file that causes it to boot loop if you don't upgrade from a previous version well living /system in tact. An actual dev might want to take a look into that.
Hope that helps!
