I have had issues with cm9 touchscreen since it began... Angry birds space is wonky at best sometimes becoming unresponsive.... The same goes with jelly defense... The touch screen just stops working...I didn't have any issues with cm7 or miui
I guess, I haven't really tried. I know that in the init.rc file, I see that the call to start sysinit is in there.
#!/system/bin/sh
touch /data/local/tmp/init.d_log_test.txt
echo "done" >> /data/local/tmp/init.d_log_test.txt
Have tried installing 3 different times. One over 3g, Wifi, and copying from a computer. Every time the install goes way to fast and the CWM log says a bunch of stuff about set_perm issues. anyone else having this problem?
I have a file called 99test containing
Should that work?Code:#!/system/bin/sh touch /data/local/tmp/init.d_log_test.txt echo "done" >> /data/local/tmp/init.d_log_test.txt
Anyway, I stuck it in /system/etc/init.d/ and got nothing after a reboot. I noticed a symlink to /etc/init.d/ so I tried it there too, also with no results.
Don't get me wrong... I'm not asking for a fix (if even needed) just trying to figure out if this is working. This came up awhile back when I noticed that 99memory didn't seem to be working.
Thanks.
Need help i have my motorola triumph on CM9 v0.611.0 and it will reboot every 5 minutes, should i wipe the date first then reinstall it because it works good other than that and i did not overclock it.
Yes, it looks like it should work. So off-hand, not sure why it doesn't. At some point, it'll probably need to be looked into.
Have you done a factory wipe/reset and then done a fresh install? Also, did you make sure that your downloaded file was not corrupt? Check the md5 sum and see if it matches what I posted.
Anyone have a chance to try playing movies from the sdcard yet in a player?
I am also having issues installing the zip. I had v0.6.10.03.0 but then flashed back to CM7 to use the camera. I wanted to just reinstall the CM9 rom instead of using the backup but I could not get past the splash image. I knew something went wrong when the zip took roughly 3 seconds to install. The exact same issue happened with the latest update as well. I always factory reset as well as format the system. The MD5 sum matched my file. I am lost.
MMS Doesn't seem to be working for me, whenever I get an mms, it pops up with the download option and ever stops downloading the image, and I never get the image. What's up with that?
after flashing 6.11.0 all the contacts I added my self were wiped, wth?
Thanks.
I'm running 6.10.3 and have from the first flash. I've been having some issues with my reception. As far as I know I'm running the stock radio and PRL. I never changed it and I've only flashed MIUI and this.
I think my problem is that I continually lock on to the wrong tower. I'm constantly seeing an 'R' next to my signal with no bars and no 3G. I can cycle Flight mode and it will most often find a connection after that, but It shouldn't be having this problem. I never had it before with MIUI.
Unfortunately, I think you are right. Incredicontrol voltage settings are not being retained and set at boot after all. It held the settings once after I renamed the init.d file/folder. After that though, it would just revert back to the defaults. I used to titanium backup to convert incredicontrol to a system app, but this did not help.
It's really strange. Are you doing a format system in addition to doing a factory reset/wipe data? If so, that is one step that I never do and have never had a problem.
If you don't mind doing a quick test, please try this:
1. Restore a backup-any backup.
2. Reboot the phone into the ROM--just to make sure that it restored ok.
3. After the phone is fully booted up, reboot back into recovery.
4. Do a factory wipe/data reset.
5. Flash the cm9 0.6.11.0 Zip file.
6. Reboot.
Does it boot now?
I just tested sending and receiving an mms containing pictures. I was able to download the received mms fine and the sending worked as well. This is using the stock mms.
As for your contacts, did you make sure that your account was set to sync to google? If it wasn't synced, then it probably got wiped out. You can check on your gmail account in a browser to see if your contacts are in there--which it should if your account was set to sync.
6. Reboot.
Does it boot now?
Ive just downloaded the newest CM9 file update (0.6.11.0). You tube appears to work fine. When I try streaming a movie through Netflix, I get sound but no picture. The screen goes dark. Is there a fix for this or is this still being worked on?? Also, just to let everyone know, I had downloaded the previous version of CM9 and just cleared cached and installed the update. Then I was puzzled that when I when into my contacts, they were gone and when I went under accounts and sync (in settings), my google account was gone and no way to attach my google account. I went back and reinstalled the CM9 Gapps file and my contacts are now there, along with my google account in accounts and sync. Just thought I would let everyone know. By the way, good job on the rom so far.
