reddeaddorito
???would getting just flash to work (camera flash) be easy? That's the only thing I liked with the cam tbh since I don't take many pictures. Trolling people with flash is the greatest![]()
ok, just noticed this. After switching to 6.11.0 some of my contacts were missing. I then checked my google sync google is no longer available as a sync option. I then tried to launch the play store and it wouldn't try and then kick me back to the home screen. What's going on?
crap, just realized that I have to reflash GAPPS too. didn't realize they wouldn't stay after an update.
Just an FYI, Google Earth now works in 6.11.0.
Also, I never got a response on my signal issues. Any thoughts from the devs?
Mantera have u heard anything from yumbrad lately or is he still off the grid just wondering somebody had said he was working on camera
Yup, "format system" causes bootloopsOk, that confirmed my suspicion and I just tested and was able to reproduce your issue.
It seems that if you do a "format system" in CWM, it seems to format system into a format that is causing the bootloops.
You should NOT be manually doing a format system in CWM before flashing any future CM9 updates since flashing the ROM will automatically format system into EXT4 format properly.
Doing a factory wipe/reset data is fine.
Okay, noob question but when updating from 6.10.3 can I just wipe the cache and delvik cache without doing a data/factory reset so that I can keep all of my apps and not go through the entire process of installing? Thanks!
Correct. You can just install it over the previous build and all of your apps will remain. HOWEVER, if you run into issues, your first troubleshooting step should be to try a clean wipe/reinstall before reporting it as a "bug".
To tell you the truth, I usually don't even bother wiping cache/dalvik cache in between builds.
It was all good! And thanks for the tip about not wiping cache/dalvik cache because if it's two processes that I don't have to go through then I'll be happy with that lol
Oh something else that I thought I should advise you on, when I go to change my profile by holding the power button and getting that menu, I select work or home but see no changes on the home screen. Is there something I'm doing wrong? I moved one of my icons on the Default profile then I selected the work profile and the icon didn't go to it's original position. Unless I'm thinking that the profiles are like those on an HTC device...
I think the profiles let you set what apps are started/running based on the application groups, volume settings, if wifi/bt/gps, etc are started, and so on only. It doesn't affect positions of icons as that is a launcher function.
Hi just downloaded the zip and about to flash. Just want to ask if its stable enough to use as an everyday ROM. i don't use my phone much just text messages, occasional calling, and taking pics. This ROM looks awesome so far BTW can wait to try it out![]()
Ahh, I think I screwed something up. I was running 0.6.6 and decided enough had changed that I was ready to take the time to update, and so I moved the new zip and gapps over to my SD card and booted into CWM recovery, then wiped data/factory reset and formatted cache and data. Now however, when I try to install from zip and select the 0.6.11 zip it gives me this in the console:
"Finding update package...
Opening update package...
Installing update...
Install from sdcard complete."
It never actually installs the zip and my CWM wont mount USB storage so I have no idea what to do from here. Help is appreciated!
Did you wipe dalvik cache too? Maybe try to download it again it the zip might be corrupt
Just wipe again but only wipe data factory reset don't format system then flash the rom
I used that micosd-sd card thing to replace the zip with a newly downloaded one and then put it back in my phone. Im running into the same problem, its not installing and it just sits on the Motorola splash screen. Im just going to try to flash back to an older version :/
