Twizted6789
Yes that is all Im doing. I cant even flash older versions now its not installing them.
Can u successfully flash any other rom or is it just the cm9 roms u can't get to flash
Just the newer ones, I was able to flash the earliest ROM available in this thread. Odd.
EDIT: After installing the base ROM, I was now able to flash the latest. Success! Thanks a ton for the help Twizted!
Thanks for the post.
I know it's bad, but at least it ain't just me, you know?
I don't use incredicontrol, but I think it uses init.d scripts.
I use System Tuner Pro for clock speed, gov, Mem, voltage, I/O... everything. It can set these via init.d (best) or just "on boot"... don't know really how that works, but the settings are reinstated using this method.
Thanks. Trying system tuner pro now. It is good that it provides another option than init.d. I am able to change the voltage now.
BTW, incredicontrol does use init.d. The author recommends that conflicting entries in that file be deleted.
Just a heads up, but Temple Run doesn't work. I assume its not the only one.
Thanks for the report on Google Earth. Probably all of those video fixes fixed it too.
For your signal issue, I haven't noticed any difference between this and other roms. Check your numerical signal value and not the bars. The bars may look different between roms based on how it's coded to show but the numbers should not be that different. Menu --> System Settings --> About Phone --> Status
Thank you to everyone who has worked on this rom. I use it daily now and it really is fantastic.
My last charge with this rom lasted me 4 days 11 hours (90-30%)
Just be careful when scrolling the voltage table screen. If you haven't noticed, it's too easy to inadvertently change an individual speed's voltage. Talked to the dev and he's looking into tweaking the ui for that screen.
Anyway, sounds like Mantra has it fixed for the next release so you can switch back to init.d or incredicontrol if you want.![]()
I've been using this rom for a while, and I know it's in alpha but I haven't seen anybody mention these problems yet. I cleared data, factory restored and flashed to alpha 0.6.9.4.
Sometimes when I go to a no signal area, and go back into an area with signal, my phone stays on R and it'll say digital roam on the lock screen. It doesn't seem to lock back onto a signal after. Airplane mode one/off works to get my phone to acquire a signal, but then 3G refuses to connect. The only way to reconnect to 3G is by rebooting the phone. This happens probably 2 out of 5 times.
Another thing regarding 3G is that sometimes it just "breaks", even if I have signal, the 3G icon vanishes and I'm not connected to 3G anymore. This happens roughly twice a day. Only way to fix this is by rebooting phone. Airplane on/off doesnt work.
Also, I've had many instances of texts not going through using Handcent SMS. The same applies with the stock messaging client too. I've sorta replicated failing to send sms's a couple times and I think that if I send an sms and immediately lock the phone, sometimes the phone doesn't send the text. When I go back into Handcent, the message indicator status just keeps spinning indefinitely. So right now, my only solution is to watch the text until it completely sends.
Other than those two problems, which don't very bother me very much as I've gotten used to them, I really enjoy using this rom as my main. Thank you devs for all the hard work!!![]()
I experience this too. I just assumed my phone was defective.
How the hell? I find this hard to believe, especially since you didn't post any pictures. Unless you turned off ALL radios, put the brightness down to the very lowest, underclocked and undervolted, and kept the phone in sleep for 4 days and 10 hours, there's NO way you got that much charge! (*hoping I'm wrong*)
Yes, I did notice. I ended up scrolling on the far right side of the screen to avoid that. The first couple of times I had to restore the defaults and start over b/c I didn't know what the original setting was after accidentally changing the voltage.
I wasn't able to set voltages below 750 even though I have heard people with MTs setting them as low as 600 at lower frequencies. Phone would also reboot on voltages higher than expected. I was able to set lower voltages on incredicontrol. Of course, this was probably because it didn't actually make any setting changes at all. When the init.do is back online, I will be able to check to see if it would be possible to set lower voltages using incredicontrol.
Here's the screenshot. Sorry, I actually charged up to 100% that time so it's really 100-27%. I use airplane mode at night and when I'm somewhere without signal. CPU is set to 122-1024 with the interactive governor. Besides that, though, I don't do anything to conserve battery.
I should also mention that the steep line down at ~50% is when I updated to 0.6.11.
I'm lost here do I download 0.6.11.0 or 0.6.11.1
Minimum stable voltage is independent of what app writes the script file.
