thangfish
Android Expert
Assuming all thatIn general though, nothing there seemed to be definitive since there is no way to measure the actual voltage, It seems like the best that could be done is an indirect test. For instance, if the system uses the lowest supported voltage when someone tries to enter an unsupported number below that, it should default back to 800. Assuming that 800 is stable at the lowest frequencies, that should also mean that any value that I enter should be stable at those frequencies. I should not be getting any reboots at the lowest frequencies because it should always default back to 800 if I enter any values below it. Yes?
yes... that is the way I understand it too.
