Mantera : Netflix stays at the loading screen nothing happens.
Oh well. I didn't have high hopes.
As Mantera said, CM9 is not reading your correct prl.Anyone have any luck changing the PRL for CM9? I tried the method that requires flashing to stock. I was able to change the PRL in stock and it stuck, verified by status listing. However, when I flashed back to this CM9 alpha, it did not stick: stock PRL was listed in status.
I tried the CM7 quick change. It did seem to put the phone into diagnostic mode when in CM9, but QPST could not write to the phone, always returns the following NV write error: NV_UE_IMEI_I NV_READONLY_S
It could read data from the phone though.
Anyone have success updating the PRL for this ROM? Thanx.
Is there anyway to have led notifications for texts and missed calls?
I mean other than the green .
There's no user setting to change it, if that's what you're asking. I changed it from red (in cm7) to green which is the same as on stock froyo.
Mantera how's the camera development going?
Hey mantera, what's the point to all these tiny kernel version jumps? More features? Are you prepping us for a 3.0 kernel? Thanks for your work.
Yeah, I don't really mind the color but it would be great that it'd worked with SMS notifications.
I haven't looked at camera. Not sure if anyone else is. I assume that edowar is still looking into it.
Been looking into a new kernel with most of my time. and updating the current kernel whenever I get tired of playing with the new one.
I like having the latest versions of stuff and the 2.6.32 kernel's latest version is .59. So just working towards that. There's a lot of fixes in the little increments to to improve the performance/stability of the 2.6.32 kernel.
BTW, in case you all haven't noticed, with the latest improvements in version 0.6.11.x and current, our nenamark2 scores have improved to about 26+ fps from the 23 fps in previous builds.
Flashing a ROM does not change your prl.
If qpst could read from your phone, it almost certainly successfully wrote the prl file to it.
... And you will always get that NV write error. Ignore it.
Is there a way to disable auto-brightness somewhere? I've checked in all the settings and can't find a way to disable it.
Funny, I'm looking for the check box to enable that. Let me know if you find it.
Did the navigation setting to enable on-screen keys get tooken out with the new build cause I can't seem to find it
i just noticed something very strange and i hope its just me. maybe it's the build, or a little bug in the bigger ics. maybe i did something wrong. i've corrected the problem, but:
i'm using the default email program and just put gmail in there. when i was sending email from my phone the other end saw it as coming from:
MY_PASSWRD <MY_GMAIL_ADDY>
the problem was fixed with a simple look at settings. but, it seems a little scary.
much thanks to mantera and the whole team for all of your work.
Do you mean the android keyboard? If so, activate your desired keyboard from "Language and Input" in settings.
