TheBritton
Resident Galaxy Cat
What does "btwlancoex" do?
Allows you to use bluetooth and wifi at the same time. Requires a lot of cpu power and battery though.
BT(Bluetooth) WLAN (Wireless LAN) CoEx (CoExist)
I assume?
I assume?![]()
According to other phones, the reason Netflix isn't working is due to a faulty graphics driver, not due to problems with flash. Not sure if anyone knew this but throwing it out there.
You're being sarcasticthat would explain why the youtube app and netflix app don't work properly since they both don't use flash then. So it makes sense.
You're being sarcastic![]()
. But you contradicted yourself sayingSo it makes sense.
Showing that being you was being sarcastic...that would explain why the youtube app and netflix app don't work properly since they both don't use flash.
Ok jjhon said that youtube and netflix are faulty because of flash with is effected by faulty graphic drivers; then you said in your comment that it all make sense now because of his information he provided . But you contradicted yourself saying
Reread his post.... It says NOT due to flash.
Lol I'm not sure if everyone is agreeing or making fun...![]()
I didn't see the not after the comma. My bad lol
Been watching this thread from birth... thanks Dev's for the work you put into this.. i haven't tried it yet.. still holding out for camera...but i must say.. great job.. keep it up!
-BG
Haha me too, I'm holding out on the camera. Apparently a lot of the dev's left the triumph behind and went to Sprint?
Hey, so I had kind of an idea the other day, feel free to tell me I'm an idiot.
What if we had the menu button bring up the multitasking thingy instead of having to hold down home?
It would give more of the experience Google had in mind without having to devote screen real estate to the software action bar buttons.
You wouldn't lose any functionality because ICS is designed not to have a menu button anyway. You'll notice that if you turn the software buttons on in this ROM, all the apps will then have a menu button usually in the top right. We'd have to have the system act like the software buttons are being used when they aren't, I guess.
There is the problem of apps built for Gingerbread or lower needing a menu. In that instance the action bar provides a menu button, but we won't have that option. I'm sure there's a way around that, though. The HTC One X, for example, has capacitive buttons instead of software buttons and I don't think they wouldn't have thought of that.
Plus, that button looks a lot more like the multitasking panes than it does the ICS menus.
Whaddya think?
Whaddya think?
Is anyone having problems with people calling them . I have 1 of my friends try to call me and I could not receive their call but I was able to call them then they tried to call me again and I was able to receive the call.
