craig71200
I took a battery tweak file from the Motorola Defy and it seems to work... if nothing else it at least gives You the percentage left on the battery icon...... Its called 1% battery zip.
It's already in CM9:I took a battery tweak file from the Motorola Defy and it seems to work... if nothing else it at least gives You the percentage left on the battery icon...... Its called 1% battery zip.
Using 0.6.14.1, having trouble of deleting apps. Keep showing me computing the storage, and when I uninstall apps, it stuck in uninstalling.
Using 6.14.1, does the battery adipose to drain so fast? I might get about 8 hours, where at first I was getting 12 hours
I don't have a problem uninstalling any apps when uninstalling using Manage apps. You may have a bad flash. Or if reflashing doesn't work, you may need to do a full wipe/data reset.
If you're using wifi or bt, your battery "may" be discharging faster since btwlancoex is enabled in 0.6.14.1 which will cause your cpu to be running at full speed all of the time when either bt or wifi is enabled. If you don't have a specific need to have btwlancoex enabled, then you may want to consider switching to v0.6.14.0.
I've been searching to no avail, what is the reason to have btwlancoex enabled?
Thanks for the fantastic work on this rom, by the way! Love it!
I just checked. The links work fine. The files are kind of big so either be on wifi or download it using a computer. Also, if you are using your phone, you may need to change the user agent for your browser to desktop according to some other posts I've seen.
I try from phone and tablet and it just takes me to a blank white page
Thanks for all of the support everybody.
For anyone that's having troubles with the softkeys not lighting up, you can do one of the following for now:
1. Enable automatic brightness: System settings --> Display --> Brightness
and check the box for Automatic brightness.
or
2. If you don't want to use the automatic brightness, you can do this but this will only work until the you reboot, then you need to do it again:
a. Enable Automatic brightness.
b. Click OK.
c. Disable Automatic brightness. The softkey LED's will work now as expected--until you reboot.
awesome the camera is almost fix cant wait when its fix good job devs
where did you get this info?
Is there a way to switch between multi tasking styles ? I kinda prefer the stock one . Thanks![]()
d4rom said:Me too.....the stock is nicer...
On AOKP you can switch between 3it would be nice to have something like that in CM9
