Me too.....the stock is nicer...
yeah, the ICS switcher is much nicer and faster.
I think I have a couple CM9 backups stored but with their present titles, I can't tell which is which. Is it alright to rename the backups or will CWM not be able to use them properly?
Oi the battery life is horrible. I don't know how you can use this rom as a daily.. Why is the battery life so different than cm7??
See if your phone is going into a deep sleep. I was getting 1% an hour of discharge on deep sleep when I used CM9.
How can you tell if it goes into a deep sleep?
If it's not how do you change it?
So it says 0% Deep Sleep and 82% at 245 MHz... how do I tell what's keeping it from a deep sleep. I turned of Auto Sync and no chnage per CPU Spy
well this phone is officially dead, looks like I'll be moving to the unlocked Galaxy Nexus![]()
Same here. I might get a SIII or GN.well this phone is officially dead, looks like I'll be moving to the unlocked Galaxy Nexus![]()
i have the same issue but i'd download some apps that they recomenend on the forum but i havent seen any change for fix the promblemHad to jump start my phone today, I've been running this ROM for a week and liked it, but the last few days it seemed the battery never fully charged. Normally I plug it in overnight and it's charged for the next day. The last few days the red charging light is on as about 12 hours of charge. Needed my phone with me so i took it and it went dead in about 5 hours.
Got home and plugged the charger in and ----- nothing. No red light, no activity at all. left it plugged in over night and the next day once again nothing. I had put a chrage on my old optimus V so I pulled the battery out and jumpered it to the Triumph and the phone booted. Plugged the USB charger in and disconnected the battery and the phone went dead.
Reconnected the battery, did a wipe of the cache and a reset and installed CM7 put the battery back in and now it's charging. what was the issue with the version of CM9 I was running/ Anyone else have the same issue?
