it would increase the system size which kinda goes against what this rom is about.hi Dan.
was wondering if adding some sort of 3g data control to reduce battery drain
might be possible? I think I've seen it on some roms
cheers
dan
true I guess.
I tried an app but it told me that GB prevents this action :-\
will try some others
cheers
nah, just turn off auto updating and leave it.What is the latest news on the SuperUser update? Is there an update that is okay to use? If so is there a link for it?
it might not be the rom, infact if youve wiped and reinstalled i very much doubt it is
its either your apn settings or your provider has problems/disabled data
Thanks, that's what it was. I've never had to manually set up apn before.have you manually setup the apn settings? no auto here
Hi SUroot!
As always, my questions might be daft in the extreme, but here goes...
Got to thinking the other day, when trying to update flash player and angry birds rio. Since you use a script to bind the market update cache to the /data-partition, I needed in the neighborhood of 40 Mbs free space on the before the updates would install. That flipping low memory warning again...
My thought is: how much use is this cache binding script, if I still need to keep up to 40 Mbs free on /data? Would your hboot partition table with a 25 Mb /cache, instead of 5 Mb, do the same job without this script? Then you'd get the warning at the ususal 15 Mb free /data at the same amount of usable /data (40 Mb - 25 Mb = 15 Mb)
