Rastaman-FB
Extreme Android User
hi Dan,
finally got dGB installeddloaded it on pc and then copied it to be sure of file
looking good so far - does seem lighter than redux2 even with out the hboot thingy - plus good to see 'move to sd' option back working in full
cheers
dan
what youll find is there is no a2sd so you will run out of space like you do on stock htc roms if you dont change the hboot to something that suits the rom
redux has a2sd support
