And you flash the man u kernel as any normal zip file is that correct? If so, this is my amended plan of action
1.Do all back ups
2. Wipe/factory reset
3. Flash dGB
4. Flash manu kernel
5. Reboot into fastboot mode.
6. Open up Android Flasher
7.Connect phone whilst in fastboot.
8. Tick hboot on Flasher and find the hboot.img that I've downloaded from the dGB thread then let Flasher do it's thing (how long does this part take and does it say when it's done?)
8.Reboot and re-install apps using Titanium
9. Have cup of tea and relax.
have i missed anything or need to do anything in a different order?
hi guys,
oooo - do i need manu kernel?what bit of the rom is it and how is it better than the existing one? thanks
1.Do all back ups
3. Flash dGB
Its the recommended one, yeah. Its the kernel, the core of android. Better battery life.
Between 4 and 5, boot the rom and check it out. Then boot into recovery and perform a nandroid backup.
Your install of the kernel will probably fail, giving you a signature error. You have to toggle it off first in recovery. I use amon ra recovery and it's under "other". Cant remember for CWM?
Cool. Forgot to mention that I was tinkering with it last night and have a nandroid backup of dGB with a few essential apps on but not all my apps so I shouldn't need to do this. I thought it would be best to restore that back up install the hboot and then just install the apps that I haven't put back on yet.
The recommended kernel (linked) is 1.4, not 2.0. I don't like 2.0. 1.4 is better battery than redux and 2.0ok cool thanks Dan
just spotted in another thread by Ducky that some peeps were having issue with the manu 2.0 kernel - and not getting better battery that redux :/
......maybe i wont rush into it then![]()
wow! still 98% after 2hrscool
managed about 1.5 days of moderate use. not as good as I was hoping but I think
better than previously. the drain seemed to increase after first few hours.
the phone shut down at 19% left. is that something I should be avoiding?
ie it getting that low
cheers
dan
