Yes, I was replying to your post 595, but by the time I'd posted that you'd posted 597 (which did things in the other order), so I amended to match that and try to make my post in some way not wholly redundant!
Yes, I was replying to your post 595, but by the time I'd posted that you'd posted 597 (which did things in the other order), so I amended to match that and try to make my post in some way not wholly redundant!![]()
hi Jon,
i used the android flasher that Dan links in the first page of this thread (i think that was where it was) worked fine for me -cm7v2 flashed
cheers
dan
Main precaution is to check the md5 of the hboot before flashing. If that checks out you should be fine.
Can't advise on android flasher - I just used fastboot flash.
yes always use fastboot to clear cacheJust to say thanks for really excellent ROM. Been in use a week now and no major issues.
I had a bit of a scare after flashing the new Hboot. I flashed the ROM on my current Hboot (was created using Thalamus's hboot tool). Installed ok and booted up fine. (I've done this a few times before)
Did a Nandroid and cleared all the data. Into bootloader and flashed the Hboot (60mb) using Android flasher. It booted back to the bootloader and showed new Hboot. When i then tried to boot back into the recovery (4EXT) it partially loaded the screen (no menu). Ok. Powered off, back into recovery, recovery menu showing ok this time. Tried to select wipe options again...blank 4EXT screen?! Back button back to menu.
Thought maybe partition table struggling, so i flashed the 65mb HBoot and worked ok. I did also have a problem with USB in Fastboot mode, but a battery pull cured that. Related ?
I think it may have been an issue with not clearing the cache when using Android flasher? Any thoughts ? I'm now set up to do it properly with ADB/Fastboot on pc
Anyway, just thought i'd share it with you. ROM is the best thanks....![]()
At the moment, my new build machine doesnt like my dGB sources so I think i will need to bring over a few files from backup, but its working on ICS right now.
