Rastaman-FB
Extreme Android User
refer to the fastboot/adb faq my friend
your network increased capacity in your area?All I can say is same kernel [Man.U 1.4] and radio [5.17.05.08] were used before on Redux 1.2 and Redux 2 and am getting better reception. From no signal to H in identical places [eg same parking bay where I go and pick my son up from work], something has changed. He has noticed a change already. Some things just can't be explained [like why Luton are in the Conference and not the Premier League lol]. Just one of life's mysteries.
Since I started using dGB, West Ham have shot up to a comfortable 2nd in the league. Coincidence? I think not.
ha, I knew there was some behind the scenes wizardry going on.I changed the boot source
Can you change something else to help my team out?![]()
Hi,
I'm interested in trying this ROM on my Desire, which is currently running the HTC developer release of Gingerbread. I'm a complete newcomer to this and have never installed a ROM before. I've rooted using Revolutionary, taken backups of everything via MyBackup Pro (plus APN backups using APN Backup & Restore from the market), and taken a couple of Nandroid backups. I've read through the rooting FAQ but still have some questions...
1. My Desire has a 4GB micro SD card in it. I've copied the contents of the card to my PC. Do I need to repartition the card / erase it / reformat it?
2. I've downloaded the 65MB hboot, plus the dgb .zip file, and also the new kernel as mentioned on the OP. Is this all I need?
3. As for the install order, am I right in thinking I do the following:
a) Go to CWM and do a "restore to factory settings"
b) Flash the hboot via CWM.
c) Install dgb.zip via CWM.
4. What about the new kernel? Where / when / how do I do that?
5. Is there anything else I need to do then? Obviously restore my stuff from my backups / Google (e.g. download my apps again, restore my SMS, reconnect to my Google account to get contacts / calendar) but what about the audio stuff mentioned on the dgb site (the link doesn't work by the way) or the apps listed there, or the fonts?
6. If I install this and don't like it for some reason, do I just reboot to CWM and restore my previous backup?
Thanks for your help and patience. This looks like a great ROM.
That's like re-coding android to become a lawyer. Some things no amount of code can fix
