autobrightness doesnt have a mind of its own but it can be a bit "off"Thanks Dan - will try Ringdroid.
Still looking for answers to the other questions (fuzzy wallpaper, getting the old notification sound for texts, haptic feedback not working, installing fonts.)
New questions:
1. I've downloaded the Clicker_Hi.apk from the Ultimate Toolbox thread but can't fathom how to change from the "standard" keyboard.
2. Is it just me or does the brightness have a mind of its own? I have it set on auto and despite the light in here being constant the phone is changing constantly.
this is the case for nearly all aosp roms ive experienced (thats all of them so far)
as for your issues with the wall paper. use quickpick to chose the picture and then maximise the crop size and it should be ok. did you download this picture over 3g or wifi or was it on the sdcard before? reason i ask is if you have freshly download it over the mobile network its probably been compressed and its not actually the phone
haptic feedback works, where are you not seeing it working?
Haptic feedback isn't working in messaging for certain - haven't tried e.g. Gmail. It also isn't working when typing into the search field in the Market, so I presume it isn't working anywhere. And yes, the option is turned on.
Wallpaper: The wallpaper is a digital camera photo which was on my SD card - the same photo I used until this morning when I was still running Sense. I've maximised the crop to fill the height of the picture and as much of the width as I can but it still looks blurry, whereas it was pin-sharp before.
Keyboard: Still stuck on the one the ROM comes with, which isn't ideal. I've downloaded the one from the toolbox (Clicker.apk or something like that?) but can't see how to change it.
when you say haptic feedback are you refering to vibration when a message is received? this is not haptic feedback. this is notification and is controlled seperately in the messaging in app for 2.3.5
go into messages>settings>notification settings>vibration and select "always"
if however you are on about the keypresses, this is kb specific and you need to enable it.
on default android kb open up the keyboard in messaging and tap the settings button, enable "vibrate on keypress"
you have to do a few things to change kb's
1st you will need to go to "language and keyboard" and enable the keyboard
after that you need to open an app that has a txt space. hold down on that space and it should say "input method" select the keyboard of choice.
the wall paper, did you use quickpic to do it? dont use the default android method one its rubbish at resizing
hi,
keyboard -i alywas use Smart keyboard Pro - it rocks - dont bother with stock stuff imo
screen - for me no issues at all - might need a full wipe and re-install? or try different images maybe
notification sounds should be sorted same way as ringtones i think
Had a look at Smart Keyboard Pro and don't like the look of it (plus you have to pay.) Anyway, I've got the keyboard working now, including the dictionary and haptic stuff.
Screen - still fuzzy. If I have to do a full wipe & reinstall (again) I'm just going to reinstall the developer build of GB from HTC. The issue is that the image looked fine under Sense, but on this it looks fuzzy. Same image + different ROM fuzzy image = not a problem with the image.
Notification sounds: I've found a zip file on XDA with the old sounds in it so I now have my chosen sound back, hurrah. Still no ringtone though. I've copied the file into the Notifications directory and it doesn't come up as an option when changing tones.
Get the feeling I'm going to be back on Sense by the end of the day. As good as this ROM looks it seems to require a hell of a lot of fannying around just to get it the way I want it. A huge shame.
well if you want sense you should use sense. people who use this rom generally like the custom stuff and dont like sense really so we dont mind going through apps etc as we would have had to do this with sense anyway as we dont like sense
for ringtones you need to create a folder on your sdcard called ringtones and place the ones you want in there. (this is android, its not rom specific)
when i use quickpic (a gallery app) to add wallpapers i dont get fuzziness. this could however be because of the res of the picture.
there are wallpaper apps about which will probably do a better job like "wallpaper set and save"
I understand your frustration with a rom like this if you come from sense with the expectation that its all there for you.
This rom is advertised as vanilla though and everything is pretty much exactly as android is before people like htc modify it to hell.
This means for people who like making the phone their own its in the best conditions. where as if you did the same on sense it would slow the phone down.
good luck though and its good you tried it anyway, its not for everyone
fresh android takes a lot of configuring, this rom is advertised as a fresh rom with nothing on it so complaining about going back to sense is a bit odd. people who dont like sense dont have an issue with that as we have to go through this process anyway even on sense just to get away from senseGet the feeling I'm going to be back on Sense by the end of the day. As good as this ROM looks it seems to require a hell of a lot of fannying around just to get it the way I want it. A huge shame.
did you read what i had said. I know its not your image, its to do with stock android (known issue) and hense why i mentioned alternative methods.Screen - still fuzzy. If I have to do a full wipe & reinstall (again) I'm just going to reinstall the developer build of GB from HTC. The issue is that the image looked fine under Sense, but on this it looks fuzzy. Same image + different ROM fuzzy image = not a problem with the image.
I realised that and thats why i mentioned in my last post that its an app from the market as i guessed you didnt realise and I didnt clarify that in my post.I worked out that "Quickpic" is an application from the Market. You seemed to assume I knew that, which I didn't
lose your attitude mate were trying to help
where have i once ignored anything you are saying
seriously though. i wont bother helping any further with people like you as i have given an answer for everything you mentioned and you reply like that..
i even gave step by steps on how to sort the keyboards etc :/
have a nice day
^^So nice, you said it twice![]()
i gave you step by steps, its unforutunate for me that you found the answer before i told you you need to create folders on the sdcard for notifications and ringtones.
I can talk from only my personal experience. i use quickpic, if that doesnt work then you will need to use wallpaper set and save. I didnt admit, if you read my first post i mention from the start that its an issue with androids cropping.
I dont use htc kb, i just know how to change the keyboards etc when you need to.
I mentioned step by step instructions for haptic feedback on keyboard, menus and messaging notification so i struggle to see where anything i have mentioned is presumption other than saying "use quickpic" and thats why i reclarified it on a later post
i even asked on my first mention about your image where it was sourced from so i could give better advice.
its not an issue of assumption. we have to ask questions in order to understand exactly what you need.
EDIT:
fonts are not my thing, ive never messed with them personally so i cant advise
if you have changed your hboot what is it? if its the 60 hboot you might need to update that to 65hboot to fit the fonts
i just downloaded beautiful widgets
the fonts are based on the skins used not the system fonts. when i changed the skins so did the font as they seem to be encapsulated into the program
ahh i didnt have those options as i was testing with superclock not home so i could only change it with skinsFor info you can change the font within the widgets. I used the default skin for the home weather and clock and it didn't appear as the thumbnail displays. By default it uses the standard Android font (the one you see on the lockscreen clock) so I found where this can be changed, which is buried within the widget display settings.
