Rastaman-FB
Extreme Android User
holla at me some time dan (su) hope you ok man
it shouldnt behave like that. i imagine you have ril issues
Other roms i've tried before and since first trying this rom worked normally, like i said earlier though it's not a problem as i never get anywhere near my data limit. Just more curious as to why it's doing it. Installed the same rom on my brothers desire & wifi works fine.
were they both bought at the same time?
which radio is your desire currently running?
it might be the ril this rom is using, are both devices the same pvt model?
Both devices pvt4, flashed ril, same result
wiped everything reflashed, same result
Like ducky1979 said earlier, it must just be one of those things because i have now flashed a 3rd desire with the same rom (all 3 desires flashed with the same rom from the same pc) and the 3d one works great too.
May just swap my brothers for mine as he hasn't a clue![]()
p.s thanks for the rom suroot, like i said earlier i have more than enough data allowance so it's no big deal & im enjoying using the rom.
Nope. Well not that you can do. Think it would be in shutdownThread.java
I haven't noticed it do a big vibrate at shut down though. You holding volume buttons at the time?
No buttons being pressed.
think mine does a 'brrr' when booting etc
Always or only when It's cold?
