how come
95havsvdd~
95dGB_Tweaks
95dGB_Tweaks~
all have the same vdd values in them?
does this mean if my device becomes unstable at 875 i will have to change it in each one of these files?
ps. flashed ontop of current build. worked fine
Beautiful!
And language support too...
Thank you very much!
had to revert back to the 1107 version as the audio stepping in media when music is playing is completely mental. when you cycle up from the volumes it goes quite to ridiculous to completely silent and thats just going up the scale. full volume is quiter than mid volume and poweramp has the limiter off so its not that
i also tried the cfs kernel and it still does it so its not kernel related
Gah, those that end with a tilde are linux backup versions. They shouldn't have been there.![]()
ahh ok i see what you mean. my bad i thought the hav vdd was a normal one and didnt have the tilde at the end.There should only be:
95dGB_Tweaks
Those ~ files are hidden backups (in linux at least). I doubt they are running. They shouldn't be there to be honest.
Yeah poweramp is a bit mad (mine is a restored version). Cleared data for it and it seemed a bit better. Need to investigate further as its perfect with google music.
what exactly did you change in the audio steppings and where?
i have a feeling its being affected as poweramp doesnt use androids internal audio engine like other apps and has its own. therefor the steppings modification you made affects what poweramp is doing
EDIT: i just read that last post and it comes across as me being a arsehole. sorry wasnt meant to seem that way, just typing as im thinking
Loving the update Susan! At least now that pesky su update won't be bothering me. It seems faster to me aswell. Cheers. Mucho love! X
Poweramp:
Settings>Audio Engine>Advanced Tweaks>Uncheck DVC is the work around. Although, not sure how much impact that will have on the pleasure you get from your audio. I can confirm it works with the new volume stepping.
i dont like androids implementation of audio its less clear.
ahh well.
I'll recompile a framework without the mod.
In fact, I think I'll add Multi-lang to one FW, get rid of the duplicate files and have an alternative FW for those who WANT the volume mod...
Hows that?
Oh well, looks like I'll have to stay on the mighty 110711, poweramp is too good!
+1, sadly i must agree![]()
