nicka3200
Android Expert
Format system, cache and data via recovery, flash or nandroid.
Excuse my ignorance. I know how to wipe data & cache via recovery. How do I format it?
should be an option in recovery to wipe system or format system.Excuse my ignorance. I know how to wipe data & cache via recovery. How do I format it?
clockworkMod 2.5.0.7
oh yeah lol im a spaz atmFormat system, cache and data via recovery, flash or nandroid.
Surely if its on SD card, if you copy everything off teh sd card, youre fine?!
Mounts and storage > Format system
Mounts and storage > Format cache
Mounts and storage > Format data
Why are you nandroiding at all? We only do that to back up the ext partition. Its simply copy from old sd and copy back to new one.
I'm not sure. What do you mean both versions?
it shouldnt matter if its not giving an md5 error then the zip is intact and it should be fine.
try install from zip without restoring after formatting system again and see if its ok.
if that has a problem still then your device maybe overheating or something
what is the pvt version?
are you using a customMTD layout rather than a custom hboot?It is PVT1. These are the ones prone to overheating aren't they?
What is a boot patch?
I've noticed that when I do a restore recovery scrolls through all the files it's restoring. I'm sure it did the same when I installed the update. Now when I flash the update zip file it just says:
Finding update package...
Opening update package...
Installing update package...
Update complete
All within a few seconds. No scrolling through files. Is this normal?
It doesnt need hardware doing at this stage. Thats a last resort. Returning to stock would be preferable to that. Flashing a stock hboot and a combination of other roms would be preferable to an RUU.... Its just what to try before that. But maybe that is the next logical step
