boot into recovery (volume down and power), restore your nandroid
hey thanks, I tried that earlier but got the same issue. I just tried it again and now getting error Run nandriod-mobile.sh restore via adb
I take it this is not good?
< this is sorted now, the battery was flat....hey thanks, I tried that earlier but got the same issue. I just tried it again and now getting error Run nandriod-mobile.sh restore via adb
I liked the option under newer market to auto-update over wifi only, so wondered if i can add market updater apk from Redux into ROM and re-flash as I've only extracted apks via 7-zip before, does adding apks also work?
And can you sort out the squinty storage lines on Ti home screen for me
Thats what I did, then I control when it updates (Except for play which they managed to push out anyway).
In that case, I will report back when I attempt to do it. Happy to help, SU![]()
I'll be honest the S-Off seems a little bit beyond me. Is there an idiot guide somewhere, cos as I haved proved on countless times its all I can get my head round LOL!!!
Hi, Your Rom is excellent ! great work !
i would like to try to compile my own oxygen to test.
can you tell us what is you locale setting when compiling minimal rom ?
i would like to have only the default English locale + french so what is your Product_locales config please ?
can you confirm your rom is HDPI only ?
best regards an keep going on !
dan@laptop02-Ubuntu:~/android/dGB1.6/frameworks/base/core/res/res$ ls
anim drawable-en-mdpi drawable-ldpi layout-port values-mcc220 values-mcc262
color drawable-hdpi drawable-mdpi raw values-mcc230 xml
drawable drawable-land-hdpi drawable-nodpi values values-mcc232 xml-en
drawable-en-hdpi drawable-land-ldpi layout values-mcc204 values-mcc234 xml-land
drawable-en-ldpi drawable-land-mdpi layout-land values-mcc219 values-mcc260 xml-mdpi
dan@laptop02-Ubuntu:~/android/dGB1.6/packages/apps/Settings/res$ ls
drawable drawable-hdpi-finger layout layout-land values-nokeys
drawable-hdpi drawable-mdpi layout-finger values xml
PRODUCT_LOCALES := en_GB
PRODUCT_LOCALES := en_GB fr_FR it_IT de_DE es_ES nl_NL pl_PL pt_PT sv_SE da_DK nb_NO
Yeah, there's no need to rush. If it makes you feel better, I was rooted for about 6 months before I tried S-Off
Read the root memory faq a few times, then ask us about anything that isn't clear. It's not that it's complicated to do, but what S-Off gives you is write access to bits of the phone you couldn't modify before, and that of course brings exciting new ways of messing things up if misused. That's why we recommend understanding it before doing it.
That made me laugh too :lol:50% courage + 35% comprehension + 15% determination = s-off![]()
