roadkill42
Android Expert
is there a way to change the WiFi icon and data to color or somthing
You can decompile or use an archiving tool to extract images and color as you like with PS or Gimp...just remember the indexing and alpha channels on the images.is there a way to change the WiFi icon and data to color or somthing
Both are nice...this one is just more "finished"Flashed 2.0 last night but guess I should've waited? Anyway, my daughter doesn't care and she likes it just the way it is! Great work!
Be sure the boot animation is named bootanimation_virgin.zip and permissions are correct.can't even change boot anamation either like I could do on moon shine and awesum why is that
System/mediawere is it at
0644 (rw r r)thanks what's the permissions to b set at never mind set to full now got my new animation thanks no need to figure out how to replace the sound with different one thanks again
If you have the stock deodexed rom pull/extract them from system/app via a root explorer or archiving tool. Email2 and exchange service I believe are the 2 apks. The google calendar syncs fine.
If ur getting a boot anim sound u must have dirty flashed as its removed in romthanks what's the permissions to b set at never mind set to full now got my new animation thanks no need to figure out how to replace the sound with different one thanks again
I just want a certain boot sound is all
Place ogg of ur choice in "system/etc" named "Bootsound_virgin.ogg" set perms "0644 (rw r r)" and reboot dont forget to make a backup in twrp just in case!!!
2nd core is online by default... Its stock kernel so no risk of overheat... Although this phone is known for heat but ive nvr had an issue im pretty sure stock thermald wont allow heat to point of hardware failuredo we need to change any settings to activate the second CPU core? and is there a safe setting to set the speeds to? dont want it to overheat as I plan on running the phone 24/7 on swagbucks
We've not worked on implementing exchange services back into the rom. I'd suggest pulling the apks from the stock deodexed rom and giving that a try.
Glad you got it working.Got exchange successfully up and running.
Thanks for the help!
