starkraving
Android Expert
Acid engine is included in this rom.I wish SRS sound enhancement was included on this ROM like moon 2.9 I switched back to 2.9 and flashed acid v8 sounds great on my system
I have noticed this too the sliders also do this... A reboot makes them update... Im not sure what needs done to fix it... Moonshine also has this issueFor some reason the toggle for the "Me" contact will not update even after updating my profile and attaching a picture. It seems to only stay as the default/blank Me. Is there a fix or workaround for this?
Lol definitely the wrong thread. Should be in the all things root thread.![]()
Yeah its called learn how to use apktool and gimpis there a program out there that will change my singnal and WiFi to multi color icons got battery done I'm running add launcher if that makes any different
Sortof it depends on what ur modifying... For images u can use zarchiver to extract then image editor to color then zarchiver to add back... For more in depth stuff i highly recommend using a pc... Biggest thing is make a backup before editing anything!!!can that b done from phone?
Those are in your systemui.apk, there are 9 images for WiFi and 13 images for signal. They will be indexed so in order to change the color you will need Gimp or similar program to convert them to RBG. Color the pngs that end in "fully" to your color of choice then reindex. Use an archiving tool such as 7zip or winrar to add the newly colored images to the respective drawable folder. This is relatively easy and theming 101 as you don't have to decompile the apk. However I'd recommend doing so as its good practice.I just want WiFi and 3g icon multi color or different then wite
This will not color our signal icons as they are different than aosp... May work with wifi...Xposed module xblast
Also note that if u modify an apk and dont resign it may not work on stock rom... Both moonshine and lawe have sig check removed apk still needs a sig but doesnt have to match as i made it return all sigs trueits beyond me for now dont have the time thanks for the info![]()
Any way to remove the battery icon in the status bar? I am using xblast and it creates another icon using the percentage the way I like it but the old battery icon remains. I then tried to use Hide Statusbar icons and that didnt work either. I have to get ride of this stupid thing somehow. Ugg
