rbheromax
Android Expert
Just chmod on install of ROMI can add the chmod to postboot... Not sure what u mean about using mksh???
Mksh is the symlink from which sh is coming from. When u add this bit from chmod, it enables root shell
Ah okJust chmod on install of ROM
not at the moment....
im sure zram is gonna be used later on down the road. one thing i noticed about my implementation is that if you add 2 or more zram block devices, it'll SLOOWWWWW down, things start crashing, because of page faults. im working through this, although while having one big zram block device, my lil phone is fine (butter)
Yeah guys this us still 4.1.2 ... Who'd know huh?![]()
Signals and batt in notification header![]()
If you type "adb remount" in term it says "adb device not found"... I wonder if its mounting partitions correctly?this adb root shell is quite limited (after chmod 4755), it does dd, remount, and other things just fine but more advanced stuff you will still need to call su as the shell (such as writing to /system otherwise you get permission denied with #)
also it may just be me, but im having trouble getting things with chmod to stick in /system also, which may or may not be part of the whole root shell problem...
i believe you are trying to do that from inside an adb shell. at that point, you are calling the binary that is on the phone, as android roms are bundled with adb so you can adb into OTHER devices. to remount system, you'd want to do either:
adb shell and then "mount -o remount,rw /system"
or
adb shell "mount -o remount,rw /system"
it seems like my /data is being mounted as jbd2 (ext4 debugging) instead of ext4 because in my processes jbd2 daemon is CONSTANTLY writing to /dev/block/mmcblk0p22 which is /data partition
I've been doing reading and the emmc issue is almost manufacturer wide...blue light of death on the Galaxy S3/4, the MotoG/X. Yeah I've read how to clear it and fully format it on XDA but I wouldn't recommend someone who's not experienced doing it.i think zte gave us REALLY BAD emmc chips...i've had lockups (where /system will not format nor mount) so I had to zero it out, and then format it again.....not everyone knows how to do this though.
Do you mean the live tiles like WiFi, signal etc?Any way you guys could implement the quick toggles like the kitkat roms. We have the look but this really would be the icing on the cake. In a matter of fact I think I will eat some now lol. Have a great extended weekend. I will work on some guides later tonight.
Oh you mean the quick access Swype to QS ...idk if its doable but it can be looked into. Keep in mind there's loads of zte code still infesting this AOSPish build... Like Bermuda grass and rag weed lol.Yes. In the kitkat builds I can swipe the upper right corner and I can get access to my toggles. Pretty nifty.
Once again all is fine my sideSays webpage not available when trying to download
